공지
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Ines_F_
초급자
5,202 조회수
Hi.  I encounterd the classical error  severe (174): SIGSEGV, segmentation fault occurred when i call the lapack subroutine GESDD on my fortran (90) program with the ifort composer 2013 Linux.
!! Decomposition en valeurs singulieres
M = Factor_long*taille; N = 2*N_Emetteurs_CBFM
Allocate( AA(M,N), S(MIN(M,N)),U(M,M),VT(N,N), WW(MIN(M,N)-1))
AA = Epatch;  call GESDD(AA,S,U=U, VT=VT, JOBZ='A')
Results on :
The real problem is that the error doesn't appear in the first passage through these code lines. it doesn't make any problem until a presize moment.
I have tried many things to rectify it : the option -heap-arrays; ulimit -s unlimited to increase my stack size .... it doesn't work.
I don't know if this can be rectified if I use the fortran Interface !?
Can I have some help if possible Pleaaaaaaaaaaaaaase !
0 포인트
15 응답
bpichon
초급자
5,202 조회수
Fisrt, did you try to use output parameter 'info' and, thus what is its output value ?
At fisrt look, it may be an 'out range subscript' in an array ; do you use '-C' option in compiler ?
0 포인트
Ines_F_
초급자
5,202 조회수
I use '-c' option in compiler, I don't know the difference between the '-c' and '-C' options. I will try to see what the output parameter INFO gives as output value. Does the 'out range subscript' can explain please that most of the times it works and doesn't in some special cases ? Thank you.
0 포인트
bpichon
초급자
5,202 조회수
-C is for 'check bound' a very useful option that I use always
0 포인트
Ines_F_
초급자
5,202 조회수
I tried to compile with the '-C' option and I get this type of problem :
undefined reference to 'zgesvx_mkl95_'
undefined reference to 'zgesdd_mkl95_'
I find this a little bit bizarre since my code worked perfectly with the '-c' option and recognize these lapack functions. You should have an idea about this problem. Can you help me please ? Thank you for your patience ...
0 포인트
bpichon
초급자
5,202 조회수
May be I an in error ...
-C seems to direct the compiler to tranform real in complex (z... are routines for complex)
For the Intel compiler, the good option is "-check bound"
SORRY
0 포인트
Ines_F_
초급자
5,202 조회수
It doesn't matter, thanks anyway for your help.
I use actually the '-check bound' option and it doesn't help me to see or to understand the problem. I still waiting for the value of INFO (my code takes few minutes becausit handles with very great problems). I wonder if the problem haven't a relation with a luck of interfacing !?
0 포인트
Ines_F_
초급자
5,202 조회수
and this is the result, I am not even able to see INFO value !!!
Image PC Routine Line Source
libc.so.6 00000032D2472BBA Unknown Unknown Unknown
libc.so.6 00000032D2474BEE Unknown Unknown Unknown
myprog 00000000005D1B8D Unknown Unknown Unknown
myprog 0000000000D8273B Unknown Unknown Unknown
myprog 0000000000BC6659 Unknown Unknown Unknown
myprog 0000000000BC6EEC Unknown Unknown Unknown
myprog 0000000000A3A65C Unknown Unknown Unknown
myprog 0000000000A2E8FF Unknown Unknown Unknown
myprog 0000000000A2B0A2 Unknown Unknown Unknown
myprog 00000000005E4883 Unknown Unknown Unknown
myprog 000000000052DE75 Unknown Unknown Unknown
myprog 00000000005096D0 Unknown Unknown Unknown
myprog 00000000005069A0 Unknown Unknown Unknown
myprog 0000000000461CCB Unknown Unknown Unknown
libiomp5.so 00002B40ECB05403 Unknown Unknown Unknown
0 포인트
TimP
명예로운 기여자 III
5,202 조회수
You don't appear to have investigated many of the steps in the article
http://software.intel.com/en-us/articles/determining-root-cause-of-sigsegv-or-sigbus-errors
0 포인트
Ines_F_
초급자
5,202 조회수
Thanks for the article, I will try to read and apply the recommondations.
0 포인트
Ines_F_
초급자
5,202 조회수
I runned the same code with ifort Compser 2013 for windows and it works ithout any problem. Does anyone have an explanation please.
0 포인트
mecej4
명예로운 기여자 III
5,202 조회수
. This is perfectly normal. The -c option is for "compile only, do not try to link". The messages about "...undefined reference to xxxx_mkl95" arise from linking without including the Lapack-95 or Blas-95 libraries. When you built with the 2013 compiler you may have specified that the mkl_lapack95 library be included, so you did not receive the "undefined reference to..." messages.
0 포인트
Ines_F_
초급자
5,202 조회수
When I tried to follow the indications and solutions listed in this article http://software.intel.com/en-us/articles/determining-root-cause-of-sigse..., with the option '-g -traceback', I got this type of error :
*** glibc detected *** ./myprog : double free or corruption (!prev) : 0x00002aaac40008co***
=====Backtrace====
/lib64/libc.so.6 [0x32d24722ef]
/lib64/libc.so.6 (cfree + 0x4b) [0x32d247273b]
/opt/intel/composer_xe_2013.0.079/compiler/lib/intel64/libifcoremt.so.5 (for_deallocate +0xb9) ....
Can anyone please help me to understand this error ? Thanks.
0 포인트
Felipe_Marchant
초급자
5,202 조회수
I do not know if it's worth even, but the problem seems to be that you release the same memory twice.
Regards.
Felipe.
0 포인트
Ines_F_
초급자
5,202 조회수
I still don't find a solution for my problem. When I apply my code to a great example, I get the same error. With
ifort -p -g -O0 -fpe-all=0 -traceback -ftrapuv -fp-stack-check -check all -debug
I still always have :
Investigating on the precise line which causes this error, it found that it always the same line :
What I found always strange is that the error is not systematic. For example, with 4 levels of the same code, it goes without any problem with the 3 first levels and it gives the double free or corruption (!prev) error while running the last level.
Since I'm sure that the problem is in relation with the GESDD, I've I thought to use an other SVD function (SVDpack for example)
Can I have please your help and if possible any information about the SVDpack and its compatibility with ifort ?
0 포인트
Ines_F_
초급자
5,202 조회수
Finally I solved the problem simply by replacing the line
with
call GESVD(A=AA,S=S,U=U, VT=VT, JOBZ='A')
the GESVD gives the same results without causing any problem.
Thanks for your help.
0 포인트
응답
