29274 Discussions
forrtl: severe (174): SIGSEGV, segmentation fault occurred
harshal05
Dear Team,
I am able to compile the calc_MAMJ_sedi.f90 code but the executable is showing the below error
Threshold Value:30 Category=hw
Image PC Routine Line Source
calc_MAMJ_sedi 000000000040C0F4 Unknown Unknown Unknown
libpthread-2.22.s 00002ADB6853FB20 Unknown Unknown Unknown
calc_MAMJ_sedi 00000000004042C9 MAIN__ 108 calc_MAMJ_sedi.f90
calc_MAMJ_sedi 0000000000402A9E Unknown Unknown Unknown
libc-2.22.so 00002ADB689706D5 __libc_start_main Unknown Unknown
calc_MAMJ_sedi 00000000004029A9 Unknown Unknown Unknown
A command used for compilation :  ifort -O2 -traceback calc_MAMJ_sedi.f90 -o calc_MAMJ_sedi
The source code of calc_MAMJ_sedi.f90,
PROGRAM SEDI_skill
IMPLICIT NONE
! THE NUMBER OF VARIABLES(M) AND THE NUMBER OF OBSERVAIONS(N), M X N
LOGICAL :: OK
logical :: iret,system
CHARACTER (LEN = 2) :: ch2
INTEGER,parameter :: nlon=61,nlat=61
INTEGER,parameter :: ndaym=7,ninit=15,npent=4,yr_st=2003,nyr=15
INTEGER,parameter :: m=21+2,nprcntl=2,nth=6
INTEGER :: i,ic,j,n,ii,jj,k,ik,kk,nt,imem,day_skip,ipent
CHARACTER (LEN=200) :: file1,file2,flin,pathmax,pathmin
INTEGER :: init,iyr,irec,i1,i2,j1,j2,k1,k2,day_st1(ninit),day_st,tst,ten
INTEGER ::ip,th(nth),ith
REAL, ALLOCATABLE :: xdatmax(:,:,:,:,:)
REAL, ALLOCATABLE :: ydatmax(:,:,:,:,:)
REAL :: UNDEF,am,rchv,ofrq,ffrq,ht,fa,ta,tb,tc,td,ss,hval
REAL :: sindex(nlon,nlat)
CHARACTER :: cyr*4,cdate*4,cpent*1,cth*2,cprcntl*2(nprcntl)
CHARACTER :: cdate1*4(ninit),ccat*5
data cdate1 /'0301', '0308', '0315', '0322', '0329', &
'0405', '0412', '0419', '0426', '0504', &
'0511', '0518', '0525', '0601', '0608'/
!data day_st1 / 60 ,67 ,74 ,81 ,88 , &
! 95 ,102 ,109 ,116 ,124 , &
! 131 ,138 ,145 ,152 ,159/
data day_st1 / 61 ,68 ,75 ,82 ,89 , &
96 ,103 ,110 ,117 ,125 , &
132 ,139 ,146 ,153 ,160/
data cprcntl/'95','99'/
data th/30,40,50,60,70,80/
!m= 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
!p=clim,sd,1,5,10,15,20,25,30,35,40,45,50,55,60,65,70,75,80,85,90,95,99/
undef=99.9
day_skip=59 !till 28th Feb
ALLOCATE(ydatmax(1:nlon,1:nlat,1:ndaym,1:ninit,1:nyr))
ALLOCATE(xdatmax(1:nlon,1:nlat,1:ndaym,1:ninit,1:nyr))
iret=system('mkdir -p data/')
do ith=1,nth
write(cth,'(I2.2)')th(ith)
do ip=1,nprcntl
if(ip==1)then
ccat='hw'
hval=3.0
endif
if(ip==2)then
ccat='shw'
hval=4.0
endif
write(*,*)'Threshold Value:',cth, ' Category=',ccat
do ipent=1,npent
write(cpent,'(I1.1)')ipent
if(ipent==1)tst=1
if(ipent==2)tst=8
if(ipent==3)tst=15
if(ipent==4)tst=22
ten=tst+6
DO init=1,ninit
cdate=cdate1(init)
day_st=day_st1(init)
DO iyr=1,nyr
write(cyr,'(i4.4)')yr_st+iyr-1
file1='/home/ERPAS/imdoper/Backup_Aditya/ht_wave/for_weekly_run/obs/heatwave_calc/new_criteria/ERPv2/ht_wv_days/'//cyr//'/MAMJ_hv_'//cyr//'.bin'
open (11,file=file1,form='unformatted',access='direct',recl=nlon*nlat)
ic=0
do k=day_st-day_skip+tst,day_st-day_skip+ten
! do k=day_st-day_skip,day_st-day_skip+6
ic=ic+1
read(11,rec=k)ydatmax(:,:,ic,init,iyr)
enddo
close(11)
file1='/home/ERPAS/imdoper/Backup_Aditya/ht_wave/for_weekly_run/model/new_criteria/ERPv2/ht_wv_days/'//cdate//'/ht_wv_'//cprcntl(ip)//'_'//cyr//'.bin'
ic=0
do k=tst,ten
ic=ic+1
read(11,rec=k)xdatmax(:,:,ic,init,iyr)
enddo
close(11)
ENDDO
ENDDO
DO j=1,nlat
DO i=1,nlon
ta=0.0;tb=0.0;tc=0.0;td=0.0
DO kk=tst,ten
DO init=1,ninit
DO iyr=1,nyr
if(ydatmax(i,j,kk,init,iyr).ne.undef) then
if(ydatmax(i,j,kk,init,iyr)==hval) then
ofrq=1.0
else
ofrq=0.0
endif
if(xdatmax(i,j,kk,init,iyr).gt.float(th(ith))) then
ffrq=1.0
else
ffrq=0.0
endif
!obs ------>
! | yes no
! | ta tb
!fct| tc td
if(ofrq.eq.1.0)then
if(ffrq.eq.1.0) then
ta=ta+1.0
else
tc=tc+1.0
endif
else
tb=tb+1.0
else
td=td+1.0
endif
endif
endif
ENDDO ! nyr
ENDDO ! ninit
ENDDO ! kk
if(ta+tc.eq.0.0.or.tb+td.eq.0.0) then
ss=undef
else
HT=ta/(ta+tc)
FA=tb/(tb+td)
call sedi(ht,fa,undef,ss)
endif
sindex(i,j)=ss
ENDDO ! nlon
ENDDO ! nlat
file1='data/sedi_MAMJ_W'//cpent//'_'//cth//'_'//trim(ccat)//'.bin'
write(11,rec=1)sindex
close(11)
enddo ! npent
enddo ! nprcntl
!deallocate (xdatmax, ydatmax)
enddo ! nth
STOP
contains
SUBROUTINE sedi(h,f,undef,ss)
IMPLICIT NONE
real,INTENT(IN) :: h,f,undef
real,INTENT(out) :: ss
real :: hm1,fm1,an,ad
if(h.eq.undef.or.f.eq.undef) then
ss=undef
return
endif
hm1=1.0-h
fm1=1.0-f
an=(f*hm1)/(fm1*h)
ad=f*fm1*h*hm1
if(an.gt.0.0.and.ad.gt.0.0) then
ss=log(an)/log(ad)
else
ss=undef
endif
RETURN
END SUBROUTINE sedi
END PROGRAM
Can you suggest me what approach I should use as I have used multiple optimization flag (O0-3) but not working.
Tested with Fortran compiler,
intel/16.0.3.210
intel/17.0.4.196
intel/17.0.5.239
intel/18.0.5.274
intel/19.0.1.144
Arjen_Markus
Usually, with this type of errors: try building with debug options on and with array bound checking and possibly other diagnostics options as well. The command-line options needed can be found in the online help or via "ifort -help".
Also: if you post code, then it is best to use the "</>" button in the expanded toolbar. That way the formatting of code is preserved.
harshal05
Dear,
Thanks for your reply.
I tried with the debug flag -g and array boundary check but it is creating any difference.  It is showing the same error  using traceback it redirects to line number 108 which contains an "if statement" and if I am changing the optimization levels it shows for another "if statement".
jimdempseyatthecove
A potential problem with your code is your choice of value for undef at 99.9. You should be aware that with floating point numbers, that fractional values often are approximations. In particular, fractions that are multiples of 0.1 would require an infinite number of bits, and yet would not be exact. This may be a case that one version of the compiler rounds up and the other version of the compiler rounds down. Therefore your (expression .eq. undef) will fail to match when it was expected (required) to match.
Try using (abs(expression - undef) < tiny(undef)) or some other larger, but smaller value
(abs(expression - undef) < 0.1) ! between 99.8 and 100.
I suspect the .eq. issue exposed itself because the xxx.bin file was written with one rounding direction and the compiled version is using the other rounding direction and thus "undef" has different identities.
Jim Dempsey
JohnNichols
Valued Contributor III
PROGRAM SEDI_skill
IMPLICIT NONE
LOGICAL :: OK
undef=99.9
do ith=1,nth
do ip=1,nprcntl
if(ip==1)then
ccat='hw'
hval=3.0
endif
if(ip==2)then
ccat='shw'
hval=4.0
endif
do ipent=1,npent
if(ipent==1)tst=1
if(ipent==2)tst=8
if(ipent==3)tst=15
if(ipent==4)tst=22
ten=tst+6
DO init=1,ninit
cdate=cdate1(init)
DO iyr=1,nyr
ic=0
ic=ic+1
enddo
close(11)
ic=0
do k=tst,ten
ic=ic+1
enddo
close(11)
ENDDO
ENDDO
DO j=1,nlat
DO i=1,nlon
DO kk=tst,ten
DO init=1,ninit
DO iyr=1,nyr
ofrq=1.0
else
ofrq=0.0
endif
ffrq=1.0
else
ffrq=0.0
endif
!obs ------>
! | yes no
! | ta tb
!fct| tc td
if(ofrq.eq.1.0)then
ta=ta+1.0
else
tc=tc+1.0
endif
else
tb=tb+1.0
else
td=td+1.0
endif
endif
endif
ENDDO ! nyr
ENDDO ! ninit
ENDDO ! kk
ss=undef
else
HT=ta/(ta+tc)
FA=tb/(tb+td)
endif
sindex(i,j)=ss
ENDDO ! nlon
ENDDO ! nlat
close(11)
enddo ! npent
enddo ! nprcntl
enddo ! nth
STOP
contains
IMPLICIT NONE
ss=undef
return
endif
hm1=1.0-h
fm1=1.0-f
an=(f*hm1)/(fm1*h)
ad=f*fm1*h*hm1
ss=log(an)/log(ad)
else
ss=undef
endif
RETURN
END SUBROUTINE sedi
END PROGRAM
JohnNichols
hval=3.0
These numbers are not going to be exact, they will have a positive tail at about 10 decimal places. You should do as Jim suggests or you will find problems.  So you number is 3 + error ===  error is always the same.
jimdempseyatthecove
Good follow-up John. Convergence limits should be based on use of the EPSILON function.
For example, to be within 3 bits of a value X, use something like
IF(abs(Y-X) < EPSILON(X) * X *  THEN
(2^3 =
Jim Dempsey
