29487 Discussions
forrtl: severe (193): Run-Time Check Failure
milenko1976
I have defined array integer,dimension(15) :: kk1, but:
milenko@milenkons:~/alo/v2$ ./oipc
forrtl: severe (193): Run-Time Check Failure. The variable 'oipc_$ITER' is being used without being defined
Image              PC        Routine            Line        Source
oipc               08094943  Unknown               Unknown  Unknown
oipc               08093660  Unknown               Unknown  Unknown
oipc               080613BE  Unknown               Unknown  Unknown
oipc               0804DB6C  Unknown               Unknown  Unknown
oipc               0804E335  Unknown               Unknown  Unknown
oipc               08049FA5  MAIN__                     20  oipc.f90
program oipc
use m1
implicit none
integer :: i,n,c,iter,e1,f1
integer,dimension(15) :: y1,w1
real,dimension(1300) :: a,b,l,d,e,f,g
real,dimension(:),allocatable :: ee,ff
open(10,file='RESP20.resp',status='old')
open(11,file='num1.txt',status='old')
open(12,file='sio.txt',status='old')
do i=1,1300
read(10,59)a(i),b(i),l(i),d(i),e(i),f(i),g(i)
59 format(7(2x,g13.5))
end do
do i=1,15
read(11,19)kk1(iter)
19 format(i3)
n=kk1(iter)
 c=4*n
read(12,99)y1(iter),w1(iter)
99 format(2i9)
e1=y1(iter)
f1=w1(iter)
allocate (ee(c))
allocate (ff(c))
ee=e(e1:f1)
ff=f(e1:f1)
call mii(iter,c,ee,ff)
deallocate(ee)
deallocate(ff)
end do
end program
What is going on?
mecej4
The error message is telling you quite clearly what the problem is. The variable "iter" is being used as a subscript in the statement [fortran]read(11,19)kk1(iter)[/fortran] but it does not have a defined value yet.
milenko1976
