29487 Discussions
forrtl: severe (29): file not found, unit 89 ?! How to solve this error?
changks888
It seems the modified Makefile works right now. However, it generates another question/error message.
What is those two lines mean? What will be the direction to solve it? The original code just ransuccessfully under Compaq Fortran Compiler, but I encountered several problems in Intel fortran Compiler. Is that possible the FFLAG in Makefile causes this error?
forrtl: No such file or directory
forrtl: severe (29): file not found, unit 89, file /Users/cks/CNCLASS/fort.89
===I post the process and error message as below=========
kuo-hsien-changs-macbook-pro:CNCLASS cks$ make
ifort -O0 -real_size 64 -integer_size 64 -save -c Allometry.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c aprep.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c canadd.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c canalb.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c canvap.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c carbon.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c cgrow.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c chkwat.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c cianda.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c classa.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c classb.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c classd.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c classg.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c classi.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c classs.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c classt.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c classw.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c commondat.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c cwcalc.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c diasurf.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c drcoef.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c flxsurfz.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c gatprep.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c gralb.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c grdran.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c grinfl.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c icebal.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c photosyn.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c precision.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c qsat.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c sldiag.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c sninfl.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c snoadd.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c snoalba.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c snoalbw.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c snovap.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c stomata.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c stomata_col.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c subcan.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c tfreez.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c tmcalc.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c tmelt.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c tnpost.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c tnprep.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c tprep.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c trim_name.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c tsolvc.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c tsolve.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c tspost.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c tsprep.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c twcalc.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c VegDyn.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c vjtmp.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c watrof.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c wend.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c wfill.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c wflow.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c wprep.F90
ifort -O0 -real_size 64 -integer_size 64 -save -c xit.F90
ifort -o runclass -O0 -real_size 64 -integer_size 64 -save Allometry.o aprep.o canadd.o canalb.o canvap.o carbon.o cgrow.o chkwat.o cianda.o classa.o classb.o classd.o classg.o classi.o classs.o classt.o classw.o commondat.o cwcalc.o diasurf.o drcoef.o flxsurfz.o gatprep.o gralb.o grdran.o grinfl.o icebal.o photosyn.o precision.o qsat.o sldiag.o sninfl.o snoadd.o snoalba.o snoalbw.o snovap.o stomata.o stomata_col.o subcan.o tfreez.o tmcalc.o tmelt.o tnpost.o tnprep.o tprep.o trim_name.o tsolvc.o tsolve.o tspost.o tsprep.o twcalc.o VegDyn.o vjtmp.o watrof.o wend.o wfill.o wflow.o wprep.o xit.o runclass.F90
kuo-hsien-changs-macbook-pro:CNCLASS cks$ ./runclass
1990 89
Image PC Routine Line Source
runclass 000000010010A331 Unknown Unknown Unknown
runclass 00000001001093F4 Unknown Unknown Unknown
runclass 00000001000D4763 Unknown Unknown Unknown
runclass 000000010009ECCF Unknown Unknown Unknown
runclass 000000010009E47C Unknown Unknown Unknown
runclass 00000001000BC549 Unknown Unknown Unknown
runclass 0000000100074E89 Unknown Unknown Unknown
runclass 0000000100000B5C Unknown Unknown Unknown
runclass 0000000100000AF4 Unknown Unknown Unknown
kuo-hsien-changs-macbook-pro:CNCLASS cks$ ls fort*
fort.100
TimP
1990 89
I hope you are able to look at your own source code. My guess is that you fail to use OPEN to create the file for unit 89 , instead depending on the compiler run time to create a file, in a non-portable style of 35 years ago. Then you assume that a file will be created with the default naming convention of some past compiler, and you fail to use iostat to help your program to display a diagnosis. Even in that style, without help from the programmer, the user may have difficulty understanding the error when the program attempts to read from a non-existent file, the run time creates an empty file, and the read still fails. I don't believe there are compile command line flags to fix this.
changks888
Quoting - tim18
Thanks Tim. You already point out the difficulty I suffered to run the whole program, such as the different user compiler, the background of programmer and users, and to understand the error. I have to think about any possibilities to make it works in this computer.
I look at the source code and only the main program entitled "runclass" has the "OPEN" setting and the unit number did not have 89 and even 100 which is thefort.100 crated after running "runclass".
1990 89
forrtl: severe (29): file not found, unit 89, file /Users/cks/CNCLASS/ fort.89
Is that possible that the I/O causes this problem?
In previous trials, I got this error message as below. The program seems to run. Because the error message was "forrtl: severe (174): SIGSEGV, segmentation fault occurred" so that I back to modify the Makefile. After solving this error, another error "file notfound, unit 89" came out. Based on youprogramming experiences, please feel free to advice more. It seems almost there, but I really need some helps. Thanks.
0
soil water balance error @ 1990 365 23 0
snow layer energy balance error @ 1990 365 23
30
1st soil layer energy balance error @ 1990 365 23
30
2nd soil layer energy balance error @ 1990 365 23
30
3rd soil layer energy balance error @ 1990 365 23
30
soil water balance error @ 1990 365 23 30
To expand on what Tim said, the program is attempting to read from unit 89 but has not opened a file on that unit. What happens then is that a default filename of fort.89 is constructed and Fortran tries to open that file. It was not found.
To solve this, you will have to understand what the program is trying to do at this point and see where it should have opened unit 89. It's possible that the program was intended to be run with an environment variable defined to point to the input file, but that seems unlikely to me.
changks888
Hi Steve,
I was looking into the source code, but I did not find any open commend with unit 89. I also use the searching tool to go through each line contains "unit", however the unit "89" did not exist. One of users ran this code long time ago suggested that to check the Intel Fortran Compiler setting, because the source code itself output some error files but may not explicitly open it in the main program(runclass). I'm just wondering the Intel Fortran Setting might be the problem. The source code was designed under Compaq Fortran Compiler. How to set up a proper compiler environment for this source code?
Thanks again.
If Makefile contains "FFLAGS= -fp -i64 -real_size 64 -integer_size 64 -nosave", then the error message was:
1990 45
starting year .... 1990
runclass 000000010005FA57 Unknown Unknown Unknown
runclass 000000010005ECD0 Unknown Unknown Unknown
runclass 0000000100000ABC Unknown Unknown Unknown
runclass 0000000100000A54 Unknown Unknown Unknown
If the Makefile did not contains any flags, the the error message was:
1990 41
1st soil layer energy balance error @ 1990 1 0
0
2nd soil layer energy balance error @ 1990 1 0
0
3rd soil layer energy balance error @ 1990 1 0
0
soil water balance error @ 1990 1 0 0
30
30
30
runclass 000000010005EAC7 Unknown Unknown Unknown
runclass 000000010005DDA9 Unknown Unknown Unknown
runclass 00000001000009BC Unknown Unknown Unknown
runclass 0000000100000954 Unknown Unknown Unknown
with FFLAGS (FFLAGS= -O0 -real_size 64 -integer_size 64 -save)
1990 89
TimP
READ(89,....) is the same as READ(unit=89,....); likewise with WRITE and PRINT. We suggested that your problem stemmed from omission of an OPEN for unit 89.
changks888
Quoting - tim18
Dear all,
It works, if I did not use the the spinup option.(I guess.)
If I use the spinup up option, it will show the error message,forrtl: severe (174): SIGSEGV, segmentation fault occurred.
starting year .... 2002
starting year .... 2003
starting year .... 2004
starting year .... 2005
starting year .... 2006
starting year .... 2007
In the source code, program uses the rand() function to randomly choose the meteorological files for rewinding files.
!-----pre-running meteorological data
open(unit=41,file="TP39_met03_class.dat")
open(unit=42,file="TP39_met04_class.dat")
open(unit=43,file="TP39_met05_class.dat")
open(unit=44,file="TP39_met06_class.dat")
open(unit=45,file="TP39_met07_class.dat")
idfile = 40+int(rand()*4+1) !open file id = 41,42
rewind(unit=idfile) !rewinding the file to the first line
print *,iyear,idfile !for checking purpose
endif
I guess that might be the reason based on the following link. What do you think? Please advice me! Thanks.
http://software.intel.com/en-us/articles/intel-fortran-compiler-using-rand-and-random-portability-functions-avoid-segv
