Dear All
I am debugging my code and I saw a weird message which is shown below.
forrtl: severe (408): fort: (8): Attempt to fetch from allocatable variable G_COARSWRK when it is not allocated
The problem is that I already checked the code and noticed that the variable was allocated as you can see below
output of code :
[0] MPI startup(): Multi-threaded optimized library
[2] MPI startup(): shm data transfer mode
[0] MPI startup(): shm data transfer mode
[1] MPI startup(): shm data transfer mode
[3] MPI startup(): shm data transfer mode
[0] MPI startup(): Rank Pid Node name Pin cpu
[0] MPI startup(): 0 58392 ceft01.grid.fe.up.pt {0,1,2,3,4,5,6,7,32,33,34,35,36,37,38,39}
[0] MPI startup(): 1 58393 ceft01.grid.fe.up.pt {8,9,10,11,12,13,14,15,40,41,42,43,44,45,46,47}
[0] MPI startup(): 2 58394 ceft01.grid.fe.up.pt {16,17,18,19,20,21,22,23,48,49,50,51,52,53,54,55}
[0] MPI startup(): 3 58395 ceft01.grid.fe.up.pt {24,25,26,27,28,29,30,31,56,57,58,59,60,61,62,63}
[0] MPI startup(): I_MPI_DEBUG=5
[0] MPI startup(): I_MPI_INFO_NUMA_NODE_NUM=2
[0] MPI startup(): I_MPI_PIN_MAPPING=4:0 0,1 8,2 16,3 24
L_CoarsWrk is allocated
G_CoarsWrk is allocated
but I do not know why I get this message. The funny thing is when I use mpirun (more than 1 processor to run) it happens and It does not show any error while running the code with one cpu.
I used following commands.
REAL(prec), ALLOCATABLE, DIMENSION(:,:,:), SAVE :: &
L_CoarsWrk, G_CoarsWrk
! Working arrays for temporal spectra
ALLOCATE(L_CoarsWrk(coars_j,coars_k,nL1))
IF(master) print*,'L_CoarsWrk is allocated'
IF(master)THEN
ALLOCATE(G_CoarsWrk(coars_j,coars_k,nG1))
print*,'G_CoarsWrk is allocated'
ENDIF
IF(master.AND.DEBGON)THEN
WRITE(logfl,'(/,"DBG: m_stats_setup OK")')
FLUSH(logfl)
ENDIF
I used -assume realloc_lhs flag as some colleagues recommended but still get nowhere.
Best regards
IF(master)THEN
ENDIF
This allocates G_CoarsWrk only on master. Are you sure you are not accessing it in any other process? As you said, it doesn't happen when
you run just one process (which is the master), I suspect this is the case.
Hi
the only command that is used by G_CoarsWrk array is in "CALL MPI_Gather" which It transfers the data L_CoarsWrk of all processors to G_CoarsWrk in master processor.
CALL MPI_Gather(L_CoarsWrk, coars_jcoars_knL1, MPI_REAL, &
G_CoarsWrk, coars_jcoars_knL1, MPI_REAL, 0, world, ierr)
! --- output through master
IF(master)THEN
WRITE(ofl) (((G_CoarsWrk(j,k,i), j=1,coars_j), &
k=1,coars_k), i=2,nG1,stat_inci)
ENDIF
L_CoarsWrk array is defined for all processors however G_CoarsWrk is defined for master.
Best regards
Is rank=0 your master?
Can you reproduce it in a demo program and paste it here?
This example works for me.
program mpi_bug
use mpi
implicit none
integer :: n,send_count
integer :: mpi_rank,mpi_procs
integer :: mpi_error_flag
integer,allocatable,dimension(:) :: p,q
call mpi_init(mpi_error_flag)
call mpi_comm_rank(mpi_comm_world, mpi_rank,mpi_error_flag)
call mpi_comm_size(mpi_comm_world, mpi_procs, mpi_error_flag)
n = 4
send_count = 2
allocate(p(1:n))
if (mpi_rank == 0) then
allocate(q(1:2*n))
q(:) = 0
write(*,*) q
endif
p(:) = mpi_rank+1
call mpi_gather(p,send_count,MPI_INTEGER,q,send_count,MPI_INTEGER,0,mpi_comm_world,mpi_error_flag)
write(*,*) q
endif
call mpi_finalize(mpi_error_flag)
end program mpi_bug
