29386 Discussions
fortcom: Fatal: There has been an internal compiler error (C0000005)
OrngD
Platform: win10
compiler:  parallel_studio_xe_2020_update4_cluster_edition
Try the following codes:
program main
implicit none
type T
integer, allocatable :: ia(:)
end type T
integer, parameter :: n = 5
integer :: i
type(T) :: Tt
! <<< Body >>>
allocate(Tt%ia(1:n), source=[(i,i=1,n)])
associate(ta => Tt%ia([1,3]))
write(*,*) ta
end associate
end program main
! It got into trouble with intel fortran. However, gfortran works well.
mecej4
Ifort 2021.1 also produces ICE. Ifx, on the other hand, builds an EXE that runs correctly.
Barbara_P_Intel
Thanks for reporting this. I duplicated the problem and filed a bug on your behalf, CMPLRIL0-33522. I'll watch it and let you know when it is fixed.
