29655 Discussions
Problem after installing Intel Fortran Compiler successfully
Nirmalendu
I have installed Intel Fortran Compiler successfully in my MacBook Pro (macOS Big Sur) and I can see the command "ifort" but when I am compiling a fortran code I am getting the following error:
ld: library not found for -lSystem
Please show me the path to solve this problem.
Thank you!
Nirmalendu
mecej4
Which version of the Intel Fortran compiler did you install?
See if this earlier thread helps to resolve your problem. See also this sticky post.
mecej4
Nirmalendu
Thank you very much. It is solved now.
