29313 Discussions
fortcom: Fatal: There has been an internal compiler error (C0000005).
phall
On 64Bit Windows using;
C:Documents and Settingsphall>ifort
Intel Fortran Compiler for Intel EM64T-based applications, Version 8.1
Build 20060202 Package ID: w_fce_pc_8.1.023
Copyright (C) 1985-2006 Intel Corporation. All rights reserved.
I keep getting;
C:Documents and Settingsphall>ifort -c -nologo -G7 -warn:all,nodeclarations,n
oignore_loc -integer_size:64 -Od -MD -Z7 -FoZ:cs_work2debugxfobexec.obj Z:
cs_work2debugxfobexec.for
Z:cs_work2debugxfobexec.for(15) : Warning: Because of COMMON, the alignment
of object is inconsistent with its type [QPMMLX]
LOGICAL QWTZRO,QFILTR,QSHEAD,QINTMC,QINTAC,QPMMLX
compilation aborted for Z:cs_work2debugxfobexec.for (code 1)
The only other message in these forum boards that is similar to this suggests using8.1.023 which I am.
This file compiles just fine in 32bit Windows, but errors out on 64 bit.
Any ideas?
If you can reproduce the problem with the current compiler version (for 8.1 that would be 8.1.038), then report it to Intel Premier Support and attach a test case. This error message is generic and simply says that the compiler got confused. It can have many possible causes and is always a compiler bug.
