29285 Discussions
fortcom: Fatal: There has been an internal compiler error (C0000005) with 11.1.060
thomas_boehme
New Contributor II
The following code results in an internal compiler error. The code doesn't do anything meaningful, it's just a mimimal demonstrator for the problem. I am using v11.1.060 Update 5.
Interestingly, it goes away when I remove the ONLY: bType from the USE in the program.
regards,
Thomas
[fortran]MODULE MOD_A
type aType
    integer :: dummy
end type
END MODULE
MODULE MOD_B
USE MOD_A
TYPE bType
   CLASS (aType), ALLOCATABLE :: B
END TYPE
END MODULE
program InternalError
USE MOD_B, ONLY: bType
implicit none
end program
[/fortran]
Thanks - escalated as issue DPD200152203.
thomas_boehme
New Contributor II
In addition to above problem with the USE, I had experienced the same internal compiler error when using type-bound functions within a series ofextended types in our code when compiling a debug build.
It took me a while togenerate a minimal reproducer for the problem(I believe it's minimal, but not sure about that...).
I am not sure whether this is the same issue as above, but it seems to be somewhat different in the sense that it occurs even without USE at all.
I really hope that these issues aregoing to befixed soon. These problems (in addition to some of the other still open problems that I reported)prevent us from using type-bound procedures in our code, which we would love to do.
Thomas
Reproducer code:
see next post
thomas_boehme
New Contributor II
[fortran]module ModuleA
    type :: TypeA
      contains
        procedure FuncA
    end type
    type, extends (TypeA) :: TypeAExt
      contains
        procedure FuncAExt
    end type
    type, extends (TypeAExt) :: TypeAExt2
        contains
            procedure FuncAExt2
    end type
contains
       function FuncA(this) result(res)
       class (TypeA) :: this
       type (TypeAExt) :: res
       end function
       function FuncAExt(this) result(res)
       class (TypeAExt) :: this
       type (TypeAExt2) :: res
       end function
       function FuncAExt2(this) result(res)
       class (TypeAExt2) :: this
       end function
end module
program YAF2003Prob
    implicit none
    ! Variables
    ! Body of YAF2003Prob
    end program YAF2003Prob
[/fortran]
Thomas,
Thanks for this latest example. It requires /debug to fail, and I think is one we have already fixed. I will verify that.
