29376 Discussions
fortcom: Fatal: There has been an internal compiler error (C0000005).
haifeng2009
I am working on a big in-house code on a new system with visual studio and intel fortran. I keep getting a strange error:
I have simplified the code to the set of the attached which reproduces the error. The attached code does nothing but having a few modules and a few declarations of variables. The compiler I use is Intel Fortran with two different versions. Both produce the same error.
 Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Inte l(R) 64, Version 13.0.1.119 Build 20121008
 Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Inte l(R) 64, Version 13.0.0.089 Build 20120731
The 32-versions seem to work all right.
The order I compiled the code is like this
ifort /c Particle_mod.f90
ifort /c BaseGrid_mod.f90
ifort /c FDFGrid_mod.f90
ifort /c FDFCellPtcl_mod.f90
ifort /c SD_Data_mod.f90
ifort /c FDFC_mod.f90
ifort /c FDFI_mod.f90
The error shows up when compiling the last file FDFI_mod.f90.
Is it a compiler bug???
Internal Compiler Error is always a compiler bug. Sometimes it can be triggered by errors in the source code, but often valid code will get an ICE.  I will look at your example and see what I can find out. Thanks.
I have escalated this to development as issue DPD200240130. If I learn of a workaround I will let you know.
haifeng2009
Thanks, Steve.
mecej4
The Version 12.1 64-bit compiler does not seem to have this problem.
This problem will be fixed in Update 4 (planned for late June.)
