fortran funtions with parameters
cvnravi
How can i write a funtion in fortran which takes both input and output as arguments.
ex: fun(integer input,integer output)
I want to make use of output value. Currently I am doint the same but the output variable is not holding the value.
I am calling a C funtion from fortran which take input and output as parameters I am able to pass input values succussfully but output is not holding its value.
TimP
As you would expect, plain VALUE attribute works only with INTENT(IN). Without VALUE, the correspondence on the C++ side is by reference or C pointer. c_ptr also could be used to pass data from C to Fortran. In case I have totally mis-guessed your intentions, and textbook examples don't fit your usage, your own example could be useful.
