fortran link-error
m_b_
Hi guys,
im using Intel composer XE 2011-VS 2008 and linked with abaqus 6.10,and the link was tested and working fine,however when i tried to use abaqus cmd line to submit an analysis i got  this error. Anyone has any clue whts the source of  this kinda error??
ifort: command line remark #10279: option '/QxW' is deprecated and will be removed in a future release. See '/help deprecated'
Thanks and any help is really appreciated
TimP
You didn't say how this might be related to Advisor; it seems more relevant to the Windows Fortran forum.  The option /QxW was replaced years ago by /arch:SSE2, which was always the default for Intel64 and was made default for IA32 as well.  This might be related to using a newer compiler than what Abaqus used when testing that version (not necessarily the wrong move on your part).
If Advisor forum were moderated as advertised (and replies not frequently blocked), someone should have replied long ago.
The message you got is simply a warning, not an error. You can ignore it or remove /QxW from the command line as it is the default.
