fortran neural networks library
kooka
does anyone knows some free neural networks library that i can use in fortran?
thanks
Les_Neilson
Valued Contributor II
Quoting - kooka
thanks
A quick Google brought up the following link (there were others)
http://www.philbrierley.com/main.html?code/fortran.html&code/codeleft.html
HTH
Les
anthonyrichards
New Contributor III
Quoting - kooka
thanks
Google is your friend.
jimdempseyatthecove
Quoting - kooka
thanks
You also might search for ANN (Adaptive Neural Networks). Most of the code basethough is written in C/C++
If the C/C++ library interface is known (it should be) then you can call the library from your Fortran code.
Jim Dempsey
