fortran,segmentation fault occured
deng_c_
hi there.  I encounterd a warning when i run my fortran (90) program:
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image PC Routine Line Source
run.x 0000000000403982 Unknown Unknown Unknown
run.x 000000000040393C Unknown Unknown Unknown
libc.so.6 00000030D9A1ECDD Unknown Unknown Unknown
run.x 0000000000403839 Unknown Unknown Unknown
this problem occurs when I enlarged my domain size(arrays).  and it can be run perfectly if I just changed to a smaller domain size.
I run this on ssh and my commands are:
ulimit -s unlimited
export KMP_STACKSIZE=9999999999
ifort -openmp Console6.f90 -o run.x
qsub Qbatche
./run.x
Does anyone know what happended?    and my complier is intel-11.1
 ATTATCHED IS THE CODE.   THANKS
jimdempseyatthecove
Your static data may have exceeded an O/S or Linker size limit of 2GB/3GB/4GB depending on circumstances. I suggest you convert your large arrays to ALLOCATABLE, then allocate at start of program. You will have an issue with the arrays that are equivalenced but these arrays can have TARGET on one and POINTER on the other. ! REAL Kappa_ex(ist+1:iet-1), Kex(ist+1:iet-1) REAL, ALLOCATABLE, TARGET :: Kappa_ex(:) REAL, POINTER :: Kex(:) ... ! in program ALLOCATE Kappa_ex(ist+1:iet-1) Kex(ist+1:iet-1) => Kappa_ex Also why parallelize: !$OMP PARALLEL Kappa_ex=1.; Kappa_ey=1.; Kappa_ez=1.; Kappa_hx=1.; Kappa_hy=1.; Kappa_hz=1.; !$OMP END PARALLEL You could consider !$OMP PARALLEL SECTIONS Kappa_ex=1. !$OMP SECTION Kappa_ey=1. !$OMP SECTION Kappa_ez=1. !$OMP SECTION Kappa_hx=1. !$OMP SECTION Kappa_hy=1. !$OMP SECTION Kappa_hz=1. !$OMP END PARALLEL SECTIONS Jim Dempsey
TimP
I haven't seen any applications which needed more than KMP_STACKSIZE=40M. Too large a value, with many threads, will consume the global stack, as "unlimited" means only "give me the maximum."
deng_c_
! in program
!$OMP PARALLEL
!$OMP END PARALLEL
You could consider
Kappa_ex=1.
!$OMP SECTION
Kappa_ey=1.
!$OMP SECTION
Kappa_ez=1.
!$OMP SECTION
Kappa_hx=1.
!$OMP SECTION
Kappa_hy=1.
!$OMP SECTION
Kappa_hz=1.
Jim Dempsey
first of all,thank you. you mentioned the equivalenced arrays: equivalence(Kappa_ex,Kex) but actually Kex=1./(Kappa_ex*rx*rt) so I can just comment it out. and it shows the same problem of: forrtl: severe (174): SIGSEGV, segmentation fault occurred Image PC Routine Line Source run.x 000000000040397F Unknown Unknown Unknown run.x 000000000040393C Unknown Unknown Unknown libc.so.6 00000030D9A1ECDD Unknown Unknown Unknown run.x 0000000000403839 Unknown Unknown Unknown and for the openmp part, you are right, actually I am new to openmp ,so I am not so sure about what I have writen in the code. thank you so much.
deng_c_
thank you . 40M = 40,000,000 actually I tried some smaller number of this,and it show directly SEGMENTATION FAULT,and 40,000,000 is useable ,and I 'll keep that in mind, but unfortunately the same error still occured: forrtl: severe (174): SIGSEGV, segmentation fault occurred Image PC Routine Line Source run.x 000000000040397F Unknown Unknown Unknown run.x 000000000040393C Unknown Unknown Unknown libc.so.6 00000030D9A1ECDD Unknown Unknown Unknown run.x 0000000000403839 Unknown Unknown Unknown so this may not be the main problem, thank you anyway :)
