29375 Discussions
-fpe-all=0 flag delivers undefined symbol: __for_ieee_store_env_
almioehi
Hy,
 Iam using composer_xe_2013.3.163/bin/intel64/ifort on a ScientificLinux6.4 machine (64bit).
The variable LD_LIBRARY_PATH is set to /global/intel/composer_xe_2013.3.163/compiler/lib/intel64/
Upon compilation with -fpe-all=0, I get the following error message:
symbol lookup error: ./a.out: undefined symbol: __for_ieee_store_env_
The other compiler options are:
-O2 -zero -r8 -i8  -mcmodel medium -shared-intel -fp-model precise
, the last one is not the source of the problem (checked that)
google doesn't even know about for_ieee_store_env.
Any ideas would be appreciated - thanks
Christian
Heinz_B_Intel
Christian
this object is defined in libifcore.so.  For me, a compilation using your switches and similar compiler ( update 2 and 4 - don't have U3 installed) don't show this problem.   Can you compile your code using the --trace-symbol option like:
ifort -zero -O2 -r8   -i8  -mcmodel medium -shared-intel -fp-model precise -Wl,--trace-symbol,__for_ieee_store_env_  foo.f
and post the output here ?
Please check too whether the right library is added too by using 'ldd a.out'. You can look at the details of the link step by  option -dryrun. May be you can see somethign unusual.
It could be related to your specific code. In case you can attach a sample showing the problem, I will look at it and will try on my system.
Heinz
almioehi
Dear Heinz,
 thanks for the speedy answer.
This looks funny to me:
original/Code>ldd ./a.out
        linux-vdso.so.1 =>  (0x00007fffc4fff000)
        libifport.so.5 => /global/intel/composer_xe_2013.3.163/compiler/lib/intel64/libifport.so.5 (0x00007fad3d8ad000)
        libifcore.so.5 => /global/intel/composer_xe_2013.3.163/compiler/lib/intel64/libifcore.so.5 (0x00007fad3d576000)
        libimf.so => /global/intel/composer_xe_2013.3.163/compiler/lib/intel64/libimf.so (0x00007fad3d0ba000)
        libsvml.so => /global/intel/composer_xe_2013.3.163/compiler/lib/intel64/libsvml.so (0x00007fad3c6f0000)
        libm.so.6 => /lib64/libm.so.6 (0x00000031e0400000)
        libintlc.so.5 => /global/intel/composer_xe_2013.3.163/compiler/lib/intel64/libintlc.so.5 (0x00007fad3c48d000)
        libpthread.so.0 => /lib64/libpthread.so.0 (0x00000031e0000000)
        libc.so.6 => /lib64/libc.so.6 (0x00000031df800000)
        libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00000031e1c00000)
        libdl.so.2 => /lib64/libdl.so.2 (0x00000031dfc00000)
        /lib64/ld-linux-x86-64.so.2 (0x00000031df400000)
and
.../composer_xe_2013.3.163/bin/intel64/ifort -zero -O2 -r8   -i8  -mcmodel medium -shared-intel -fp-model precise -Wl,--trace-symbol,__for_ieee_store_env_  foo.f
ifort: command line warning #10212: -fp-model precise evaluates in source precision with Fortran.
.../composer_xe_2013.3.163/compiler/lib/intel64/libifcore.so.5: definition of __for_ieee_store_env_
 Christian
Heinz_B_Intel
This looks perfect - nothing unusual:  You have the object defined too in libifcore and the library is found. The only item left is  a potential issue regarding the link order. Could you send me a sample source file and the exact compiler / linker invocation line ? You can use the option 'Send Author a Message' to avoid this being published. I too can send you an email thus that you can attach this to a reply.
