g-editing with Intel compiler v13.0
Harald
Начинающий
584Просмотр.
it appears that the output generated by the g edit descriptor has been changed between
version 12.1 and 13.0.  Consider the following example:
  print '(a,5g10.3)', "g10.3:", 0.0, 1.0, 1.23, 123., 1234.
  print *
  print '(a,5g10.1)', "g10.1:", 0.0, 1.0, 0.1, 0.01, 10.
end
With v12.1 I get:
g10.3:  0.00      1.00      1.23      123.     0.123E+04
g10.1:    0.        1.       0.1       0.1E-01   0.1E+02
while version 13.0.0.079 writes:
g10.3:  0.00     1.000      1.23      123.     0.123E+04
g10.1:    0.       1.0       0.1E+00   0.1E-01   0.1E+02
Is there a reason why 1. is printed differently with g10.3,
or similarly why 0.1 has an exponent for g10.1?
Harald
0 баллов
3 Ответы
Steven_L_Intel1
Сотрудник
584Просмотр.
The rules for G editing changed in Fortran 2008 and, I think, again in Corrigendum 1 for F2008. I know we made changes in this area but will have to study your example to see if we got it all right.
Harald
Начинающий
584Просмотр.
Hi Steve, I checked the table in the F2008 FDIS in section 10.7.5.2.2: Magnitude of Internal Value Equivalent Conversion N =0 F(w −n).(d − 1), n(’b’) 0.1 − r × 10^−d−1 ≤ N < 1 − r × 10^−d F(w −n).d, n(’b’) 1 − r × 10^−d ≤ N < 10 − r × 10^−d+1 F(w −n).(d − 1), n(’b’) ... I'm not sure what the default rounding mode is, but the cases of 0.1 and 1.0 of the above example appears to be covered by the lines quoted here, and the equivalent format should be Fx.y in the way generated by version 12.1, not by version 13.0. I could not find anything in the Corrigendum 1 for F2008. Harald
Harald
Начинающий
584Просмотр.
Steve,
I just checked this case with the following compiler version:
Intel(R) Fortran Compiler XE for applications running on IA-32, Version 14.0.1.106 Build 20131008
I now obtain:
This nicely agrees with the result from v12.1 and should be correct now.
Harald
Ответить
