29348 Discussions
general error c1010070: Failed to load and parse the manifest
Mike896
Hi
  As I Build Solution, it appears:
Output Window
Embedding manifest...
.\Debug\sdue2ae.exe.intermediate.manifest : general error c1010070: Failed to load and parse the manifest. {q~0H
I used to have problems of IMSL, but I have checked it and it seems ok.
I'd like to ask what the problem is.
Thanks a million.
Mike
I never saw that one before, but a Google search suggests that one possibility is too long a path for the manifest file. That does not seem to be your problem.
I suppose a simple solution is to disable generation of manifests. In the project properties, select Linker > Manifest File and change "Generate Manifest" to no. I doubt you will miss it.
Mike896
I''ve done it. But now it shows:
mt.exe : general error c10100b1: Failed to load file ".Debugsdue2AE.exe". {q~0H
I've ReBuild or Clean the solution, it doesn't work either.
I've checked the *.obj files. They are not rebuilt at all. :(
Thank you for your help.
Mike
Are those strange characters which show in the post actually in the filename?
Mike896
No. The strange characters are outside the filename. The filename is correct.
Now, it shows:
========== Build: 0 succeeded, 0 failed, 1 up-to-date, 0 skipped ==========
There is no Buildlog in ./Debug/, no ***.obj. Silent. :(
Thanks for keeping help me.
Mike
Mike896
I started a new and very simple project now.
program main
print *,'sss'
end program main
After Build Solution, it shows:
1>------ Build started: Project: Console2, Configuration: Debug Win32 ------
1>
1>Build log written to "file://D:tempConsole2Console2DebugBuildLog.htm"
1>Console2 - 0 error(s), 0 warning(s)
========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
But I don't find the *.obj in ./Debug at all.
and Build Solution again,
Still no *.obj.
Then I Run it, it shows:
Visual Studio cannot debug because the debug target 'D:tempConsole2Console2debugconsole2.exe' is missing.
Mike
Mike896
Quoting - Mike896
program main
print *,'sss'
end program main
1>
Still no *.obj.
Mike
Oh, I find out that IVF will not automatically remind user to save the newly edited file and add to the project.
I remember CVF will do it.
After I save and add it to project, it works now.
But back to my previous post, it still shows
There is no new Buildlog in ./Debug/, no updated ***.obj. Silent. :(
Mike
Mike896
Quoting - Mike896
Mike
I've redone one static-library project by collecting all the files(modules and external files) except main file.
This is done successfully.
I create a main project to add the main file and also linking thestatic library.
I compare the settings in Project->properties and find Fortran is missing in Configuration Properties for the old project.
Also there is also another Common Properties added.
Mike
Mike,
You will not see Fortran in the Configuration Properties. It will be in the Project Properties.
At this point I suggest that you enter an issue at Intel Premier Support and attach a ZIP of your solution folder. There's not enough information here so far to understand the problem.
Mike896
Mike,
Thank you for your information.
I find out I forgot to include *.mod. There are so many settings to be remebered and they appear in many places.
Mike
Mike
