get folder file contents
hra99
I'm using CVF 6.6 to create Windows programs (not QuickWin). I'm looking for a routine to create a text list of the files in a Windows folder. I found nothing in the packaged Fortran interfaces. Has anyone found or written an interface to the procedure that can accomplish this?
Harry
GETFILEINFOQQ
The DFLIB routine GETFILEINFOQQ will do this.
hra99
Thanks, Steve, this works OK. I skipped over this and other "QQ" functions since the documentation does indicate they are for Windows applications. Apparently this is not the case.
I assume you meant "does not". Yes, I can see where it is confusing there....
davinci
A small experiment with recursive search into (sub)subroutines didn't work out completely, but here is the code anyway (miss the time to complete it).
Letus know how to correct the recursion.
DaVinci (Clemens de Leeuw)
Code:
! Test recursive TstGetFileInfoQQ to seach into subdirectories:
! Create a small directory structure with several subdirectories
! and one subsubdirectory and a file in each of them.
! Run TstGetFileInfoQQ and point to the *   (append wildcard "*").
! TstGetFileInfoQQ should recursively find each subdir and file.
! It does for the first part, but then returns an "Invalid file or pathname"
Program TstGetFileInfoQQ
use  dflib
character(80) files
write (*,'(a,)') ' Enter wildcard of files to view: '
length = GetStrQQ (files)						! read or accept statement
call DrvGetFileInfoQQ (files)
end
RECURSIVE subroutine DrvGetFileInfoQQ (files)
use dflib
character(80)    files
integer(4)       handle, length
character(5)     permit
integer(2)       iyr, imon, iday, ihr, imin, isec
type (FILE$INFO) info							! structure declared in dflib
handle = FILE$FIRST								! start handle for GetFileInfoQQ
do while (.true.)
   length = GetFileInfoQQ (files, info, handle)
   if (info%name(1:1).eq.'.') cycle				! skip hidden "." and ".." system files
   if ((handle .eq. FILE$LAST) .or. (handle .eq. FILE$ERROR)) then
        select case (GETLASTERRORQQ( ))
           case (ERR$NOMEM)
                 write (*,*) 'Out of memory'
           case (ERR$NOENT)
                 exit
           case DEFAULT
                 write (*,*) 'Invalid file or path name'
        end select
   endif
   permit = ' '
   if ((info%permit .and. FILE$HIDDEN)   .ne. 0) permit(1:1) = 'H'
   if ((info%permit .and. FILE$SYSTEM)   .ne. 0) permit(2:2) = 'S'
   if ((info%permit .and. FILE$READONLY) .ne. 0) permit(3:3) = 'R'
   if ((info%permit .and. FILE$ARCHIVE)  .ne. 0) permit(4:4) = 'A'
   if ((info%permit .and. FILE$DIR)      .ne. 0) permit(5:5) = 'D'
   write (*,'(1x,a,i8,3i11,'' '',a)') &
          permit, info%length, info%creation, info%lastwrite, info%lastaccess, trim(info%name)
!  -- Date-time fields are packed, unpack these as follows:
!  call   UnpackTimeQQ (info%lastwrite, iyr,imon,iday,ihr,imin,isec)
!  write (*,'(9x,i5,5i3,/)') iyr,imon,iday,ihr,imin,isec
   pause										! test
!  -- Here TstGetFileInfoQQ should scan recursively into subdirectories:
   if (permit(5:5).eq.'D') then
       icount = icount + 1						! test
       if (MOD(icount,10)==0) pause				! test
       type *, '>>>>>', trim(info%name), ' >>>>> ', icount
       call DrvGetFileInfoQQ (trim(info%name) // '*')
   endif
enddo
end subroutine
