I have a code complied using gfortran -O3. I currently evaluating Intel Visual Fortran. What will be the equivalent flags to gfortran -O3?I the project properties, Iused Maximize Speed plus Higher Level Optimizations (/O3), however the code compiled by IVF is about 2-3 time slowers? Any suggestions?
Can you show us the code? Sometimes there are differences not related to optimization (such as the size of I/O records).
I suggest viewing this to see an overview of the VS environment.
Do you have any OPEN statements with RECL= keywords?
I only count the time without I/O statements as my I/O are localized in the very beginning and at the very end.
Try using -fast and see what it does for you.
Thanks Steve for your help. However, how to activate this option through MS Visual Studio 2010?
There is not a property for that. I did not realize you were using Visual Studio.
Let me suggest the following property settings:
Optimization > Optimization > O3
Optimization > Interprocedural Optimization > Multifile
Code Generation > Intel Processor-Specific Optimization > /QxHost
Floating Point > Floating Point Model > Fast=2
I did as you suggested, the code runs for 866.031. Using gfortran, it runs for 438.328.
Something is very wrong, but it's impossible to say what without seeing the code.
Can you give me your email address for me to send you the code? I don't want to share it on the forum.
You can provide it securely through Intel Premier Support. Please ask that the issue be assigned to Steve Lionel.
