29298 Discussions
handling big size of 3 dimension data
hyenchun
I am working on a program dealing with 3d data files.
My input filesareseries of 1000*1000 binary ascii files. I want to read 1000 files at once so I can treat as 1000*1000*1000 3d data. But the Fortran gives me an error...all these data are read as z(1000,1000,1000) and this parameter is too big for Fortran (Error: A common block or variable may not exceed 2147483647 bytes)..
I tried to seperate data into 5 parameters, but it gave me also an error (program exception...).
How can I solve this problem?
Here is a part of my code;
dimension z1(1000,1000,1000)
integer z1
character p,pp,pp2
character*80 inpfil(5000),outfil1(5000), outfil2(5000),outfil3(5000)
OPEN(4,FILE='prbinary2.i')
!First, read number of sample image and read output names!
read(4,*)nfile3
do 1 nf3=1,nfile3
READ(4,'(A)') outfil1(nf3)
READ(4,'(A)') outfil2(nf3)
READ(4,'(A)') outfil3(nf3)
1 continue
do 10 nff=1,nfile3
READ(4,*) nfile
DO 2 nf=1,nfile
READ(4,'(A)') inpfil(nf)
2 CONTINUE
CLOSE(4)
do 6 nf=1,nfile
OPEN(5, FILE=inpfil(nf))
zz1=zz1+1
read(5,11)p
11 format(a2)
read(5,12)pp
12 format(a45)
read(5,13)pp2
13 format(a20)
read(5,14)ww,qq
14 format(t1,i4,i10)
read(5,15)((z1(ii,jj,zz1),ii=1,ww),jj=1,qq)
15 format(35i2,1x)
6 continue
Hyen Chung
You are trying to declare a variable of size 4,000,000,000 which is larger than the 2GB address space on 32-but Windows. You will need to either rewrite your program so that you don't have all the data in variables at once (so that the variables can be smaller) or move to a 64-bit system (with adequate RAM and the Intel compiler for EM64T) so that you have a larger address space. Even on a 64-bit system, though, you cannot declare the array as a local variable the way you have done it here, as there is still a 2GB limit on static code and data. Instead, you'll have to make the array ALLOCATABLE and allocate it to the correct size.
