-heap-arrays flag - does it work?
Mark_Mackey
Hi all.
If I compile the following program with
ifort -m32 -heap-arrays test.f
the array in mytest2() is allocated on the heap, but the one in mytest() is not. According to the documentation, the -heap-arrays flag should put all automatic arrays on the heap. Am I misunderstanding the documentation? Is there a way to force the array in mytest to be allocated on the heap instead of on the stack or in static data?
Mark
        program test
        implicit none
        integer i,mytest,mytest2
        i=mytest()
        i=mytest2(100000)
        stop
        end
        function mytest
        implicit none
        integer mytest
        automatic bigarray
        integer bigarray(100000)
        integer i,j
        do i=1,100000
          bigarray(i)=i
        enddo
        do i=1,100000
          j=j+bigarray(i)
        enddo
        mytest=j
        return
        end
        function mytest2(isize)
        implicit none
        integer mytest2,isize
        integer bigarray(isize)
        integer i,j
        do i=1,100000
          bigarray(i)=i
        enddo
        do i=1,100000
          j=j+bigarray(i)
        enddo
        mytest2=j
        return
        end
An interesting question.
The array in mytest is not an automatic array - not by the definition of the language. The AUTOMATIC statement you used is an extension and effectively means "non-static".  I do see that, when compiled without optimization, this array is indeed put on the stack, even with -heap-arrays. With optimization, the compiler is able to compute the function value without creating the array at all.
The idea of -heap-arrays was to control allocation of temporaries and "automatic arrays" in the Fortran standard sense of local arrays whose bounds are determined by run-time expressions. I admit that the documentation isn't terribly clear on this and will discuss it with the development team.
I looked closer at the documentation and it does explain this behavior:
In Fortran, an automatic array gets its size from a run-time expression. For example:
RECURSIVE SUBROUTINE F( N )
INTEGER :: N
REAL :: X ( N )     ! an automatic array
REAL :: Y ( 1000 )  ! an explicit-shape local array on the stack
Array X in the example above is affected by the heap-array option; array Y is not.
Mark_Mackey
Ah, OK - I was assuming that the "automatic" keyword made an array automatic :).
So there is no way currently to ask that explicit-shape local arrays be allocated on the heap without doing it manually?
Correct. You would make the array ALLOCATABLE and allocate it. This is better than depending on compiler switches, anyway.
