hexadecimal numbers
Roman1
I am trying to understand how to use hexadecimal numbers properly.  When I compile the following program, I am getting the following warning when assigning a hex value to a variable:
warning #6473: Fortran 2008 does not allow boz constant in this context.   [Z'0000000F']
However, there is no warning if I fist set a PARAMETER to this value, and then assign it to a variable.  Is this the correct behavior?
program test_hexint
implicit none
integer a, b
integer,parameter:: c = Z'0000000f'
a = Z'0000000f'  ! warning #6473: Fortran 2008 does not allow boz constant in this context.
b = c  ! no warning
write(*,*) a, b
stop
end program test_hexint
FortranFan
You will find the Fortran standard (e.g., section 4.7 of Fortran 2008) state, "A binary, octal, or hexadecimal constant (boz-literal-constant) is a sequence of digits that represents an ordered sequence of bits. Such a constant has no type" (the bolded emphasis is mine) and later provide a constraint "C4102 (R463) A boz-literal-constant shall appear only as a data-stmt-constant in a DATA statement, or where
explicitly allowed in subclause 13.7 as an actual argument of an intrinsic procedure."
So you can try the following to make it standard compliant:
program test_hexint
   implicit none
   integer a, b
   integer, parameter:: c = int( Z'0000000f', kind=kind(c))
   a = int( Z'0000000f', kind=kind(a))
   b = c  ! no warning
   write(*,*) a, b
   stop
Roman1
Thanks for the information.  I thought that hex numbers can be used like any other integer.  I am still confused about the parameter statement:
Is the above line standard compliant?  My guess is that it is not, since it is not a DATA statement.  However, the compiler is not displaying any warning messages.
It is indeed nonstandard to use a BOZ constant directly in a PARAMETER - that we don't give a standards warning for this is a known problem that will be fixed in a future release.
