'home/default directory' in CVF
forall
The 'home' directory when running the CVF executable from inside CVF is the project directory, whereas when running it outside CVF its the directory where the exe resides. Is there any way to control this behaviour? I have a code that opens a data file using a relative path and this doesnt work properly when the starting directory varies.
thanks
Dmitri
You can specify the default directory in the Debug tab in Project..Settings.
gregscvf
I specify the following in all my projects/configs: ..
Greg
