hostname
roddur
how can i get hostname and memory used in a code using either ifort or gfortran? is there any standared for that? if not, can you tell me the workaround?
TimP
Quoting - roddur
You'll have to show us your problem before we can discuss work-around. 'info gethostname' or a web search will give you immediately much more information than can be repeated here. gethostname would be called identically from ifort or gfortran, provided that you use a recent version of either which includes iso_c_binding.
If you would be more specific about your memory question, you might get some suggestions, but surely you have ideas yourself.
rreis
Quoting - roddur
call system() can be used to invoke system functions/execs... maybe this can help (like external parsing of ps output)?
