29386 Discussions
how to access a pointer in C as a multi-dimensional array from Fortran??
xu_steve
Hi, everyone.
I have a pointer dynamically allocated and filled some data in C, and then i need to access it as a multi-dimensional array in Fortran. Say firstly i decalare a global pointer variable and allocate memory for it as follows in C:
doulbe *temp_d;
#define N 10
void c_routine()
temp_d=(double*)malloc(N*sizeof(double));
//fill some data to temp_d
then in Fortran i try to use temp_d as, for example, temp_d(i,j,k).
I try to use c_f_pointer to do it. For test purpose, i just write the following code and it can compile. But when i run it, i got a segmentation fault.
module c_test
use ios_c_binding
implicit none
type(c_ptr),bind(c,name="temp_d")::temp_d
real(8),pointer::temp_d_fp(:)
integer,parameter::N=10
contains
subroutine init()
call c_f_pointer(temp_d,temp_d_fp,)
end subroutine
end module c_test
program main
use c_test
call init()
write(*,*),temp_d_fp(2)
end program main
I change "real(8),pointer::temp_d_fp(:)" to " real(8),pointer::temp_d_fp", and it will not work too.
Anybody can help me??
BTW, I want to use temp_d as multi-dimensional array of arbitary bound in fortran, for example ,temp_d(-2:2,1:2), I konw for_descriptor_assign may do this, but i need to compile the code on Linux. It seems that intel fortran 11.1 donot support this subroutine on Linux.
JVanB
Valued Contributor II
I think you just forgot to invoke c_routine(). At least this works for me:
C code:
[cpp]// c_routine.c #include double *temp_d; const size_t N = 10; void c_routine() { int i; temp_d = (double*)malloc(N*sizeof(double)); for(i = 0; i < N; i++) { temp_d = i; } } [/cpp]
Fortran code:
[fortran]! c_test.f90 module c_test use, intrinsic :: iso_c_binding implicit none type(c_ptr), bind(c,name="temp_d") :: temp_d real(c_double), pointer :: temp_d_fp(:) integer, parameter :: N = 10 interface subroutine c_routine() bind(c,name="c_routine") end subroutine c_routine end interface contains subroutine init call c_f_pointer(temp_d,temp_d_fp,) end subroutine init end module c_test program main use c_test implicit none call c_routine call init write(*,*) temp_d_fp(2) end program main [/fortran]
JVanB
Sorry, I didn't take into account the last part of the original post.There are three ways Fortran allows you to set the lower bounds of a pointer. The method you choose depends on your preference and compiler.
The C code is unchanged:
The Fortran code is now:
[fortran]! c_test.f90 module c_test use, intrinsic :: iso_c_binding implicit none type(c_ptr), bind(c,name="temp_d") :: temp_d real(c_double), pointer :: temp_d_fp(:) real(c_double), pointer :: temp_d_1(:,:) real(c_double), pointer :: temp_d_2(:,:) integer, parameter :: N = 10 interface subroutine c_routine() bind(c,name="c_routine") end subroutine c_routine end interface contains subroutine init call c_f_pointer(temp_d,temp_d_fp,) call c_f_pointer(temp_d,temp_d_1,[N/2,2]) end subroutine init subroutine remap(oldp,newp) real(c_double), target :: oldp(-2:,1:) real(c_double), pointer :: newp(:,:) newp => oldp end subroutine remap end module c_test program main use c_test implicit none call c_routine ! Create 1-d pointer call init write(*,*) temp_d_fp(2) ! First method: use bounds remapping temp_d_2(-2:2,1:2) => temp_d_fp write(*,*) temp_d_2(-1,1) nullify(temp_d_2) ! Second method: specify lower bounds in bounds spec list temp_d_2(-2:,1:) => temp_d_1 write(*,*) temp_d_2(-1,1) nullify(temp_d_2) ! Third method: point at assumed-shape dummy call remap(temp_d_1,temp_d_2) write(*,*) temp_d_2(-1,1) end program main [/fortran]
xu_steve
Hi, Repeat Offender. Thanks for your help.
But i find the first and second method cannot compile on my computer. My compiler is Intel 11.1 and the compiler error is as follows:
error #6731: object is not a pointer object [temp_d_2]
temp_d_2(-2:2,1:2)=>temp_d_fp
temp_d_2(-2:,1:)=>temp_d_1
Fortunately the third method do works, but i cannot find the difference of these three methods
Arjen_Markus
The first two methods use features that have been introduced in Fortran 2008 (or perhaps Fortran 2003
- I am a trifle uncertain here), but are not supported yet by the version of the compiler you are using.
Arjen
Fortran 2003 introduced pointer bounds remapping, and the Intel compiler supports it as of 12.1.
xu_steve
Thank you very much
