Dear all,
I am using VS2005 + IVF Compiler XE 12.1.1.258 [IA-32].
I have a function called MABP located in a dll with the dllexport attribute. I want to use that function from inside the dll (in the routine called MeABP which is also exported from the dll). I have added the declaration statement of the routine (because it uses the stdcall calling convention) and I get the following warning message during the linking step:
warning #11077: MeABP.obj: locally defined symbol __imp_MABP imported
I understand what the message is saying but I was wondering if it was due to a bad programing or just a normal warning message that I can dismiss ?
It's normal - ignore it, You'll get this warning when building a DLL where you USE a module from elsewhere in the DLL that DLLEXPORTs one of its symbols.
Many thanks steve
