how to assign a double double variable?
仁义_许_
if a double variable is assigned, d0 need to be tailed.
real(8)::a
a=1.2d0
Now, a higher precision variable need to be assigned, what is tailed?
real(16)::b
b=1.2??
andrew_4619
real(16)::b
b=1.2_16
! or better
integer, parameter :: rk = 16
real(rk) :: b
b = 1.2_rk
andrew_4619
real(16)::b
b=1.2_16
! or better
real(rk) :: b
b = 1.2_rk
Steve_Lionel
Better still (and more portable):
Integer, parameter :: qk = selected_real_kind(30)
real(qk)::b
b=1.2_qk
仁义_许_
real(qk)::b
b=1.2_qk
thx!!
Then, what forms of functions such as dsqrt is?
mecej4
DSQRT is a specific function (more than one function for one purpose, one for each type of argument). Fortran77 and earlier versions of Fortran had plenty of such specific functions. Fortran 90 and later versions provide generic functions, so that you can use a single function name regardless of the type of the argument and function value. It is recommended that you do not use specific functions such as DSQRT in new code.
Steve_Lionel
RIght - just use the generic SQRT.
