how to link abaqus with intelfortran
abdelhak_a_
Dear sir,
I have installed ABAQUS CAE2016, Microsoft Visual Studio 2015, and Intel Visual Fortran Studio XE 2016 on my computer. However, when I run the test codes, there are the following errors:
Création de la bibliothèque standardU.lib et de l'objet standardU.exp
libirc.lib(fastmemset.obj) : error LNK2019: symbole externe non résolu memset référencé dans la fonction _intel_fast_memset.A
libirc.lib(fastmemcpy.obj) : error LNK2019: symbole externe non résolu memcpy référencé dans la fonction _intel_fast_memcpy.A
standardU_static.lib(SMAStsStdU_IF.obj) : error LNK2019: symbole externe non résolu __imp_printf référencé dans la fonction "void __cdecl SMABasOmniSetSSELevel(void)" (?SMABasOmniSetSSELevel@@YAXXZ)
standardU_static.lib(uanisohyper_inv.obj) : error LNK2001: symbole externe non résolu memmove
standardU_static.lib(uanisohyper_strain.obj) : error LNK2001: symbole externe non résolu memmove
standardU_static.lib(ufluidconnectorloss.obj) : error LNK2001: symbole externe non résolu memmove
standardU_static.lib(ufluidconnectorvalve.obj) : error LNK2001: symbole externe non résolu memmove
standardU.dll : fatal error LNK1120: 6 externes non résolus
Abaqus Error: Problem during linking - Abaqus/Standard User Subroutines.
This error may be due to a mismatch in the Abaqus user subroutine arguments.
These arguments sometimes change from release to release, so user subroutines
used with a previous release of Abaqus may need to be adjusted.
Abaqus/Analysis exited with errors
If you are familiar with ABAQUS subroutines and know where the problem probably lies in, could you please help me with it? Your help is greatly appreciated!
TimP
Did you install one of the qualifying combinations of vs2015 (selecting c++ support option) and ifort version?
Your link installation appears to find the ifort libraries but not the vs2015 ones.  I haven't seen such a problem without an indication of the vs library paths searched.  Microsoft changed those several times in vs2015 updates.  If you keep vs2015 up to date, you will not be able to use original minor releases of ifort.  Your abaqus may have been built against an earlier vs.  I don't know whether that would present a problem, you would need to consult abaqus support.
JohnNichols
Valued Contributor III
I just put on VS2015 community edition - to lazy to do the paperwork for the others.  I told it to install everything and then I installed the new Fortran Beta on top.
It works fine , but is this what you mean
John
TimP
All of the ifort versions 15u6, 16u3, and 17.0 work for me with VS2015.2.  The 17.0 will not have been tested by Abaqus, although I don't know why it wouldn't work.
I had to remove VS2015 entirely in order to upgrade it to VS2015.1, but the VS2015.2 update worked in place for me.  I still suspect you have something inconsistent in your VS2015.
Tomas_M_1
Hei,
have you solved this problem? I got it too! I use VS 2015, ifort tried both 16.0 or 17.0 See the log file
Analysis initiated from SIMULIA established products
Abaqus JOB xpl_user_sp
Abaqus 3DEXPERIENCE R2017x
Abaqus License Manager checked out the following licenses:
Abaqus/Explicit checked out 5 tokens from Flexnet server localhost.
<11 out of 16 licenses remain available>.
Begin Compiling Single Precision Abaqus/Explicit User Subroutines
6/23/2017 4:36:26 PM
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0.4.246 Build 20160811
Copyright (C) 1985-2016 Intel Corporation.  All rights reserved.
End Compiling Single Precision Abaqus/Explicit User Subroutines
Begin Linking Single Precision Abaqus/Explicit User Subroutines
   Creating library explicitU.lib and object explicitU.exp
explicitU_static.lib(SMAUXpU_XP_IF.obj) : error LNK2019: unresolved external symbol __imp_printf referenced in function "void __cdecl SMABasOmniSetSSELevel(void)" (?SMABasOmniSetSSELevel@@YAXXZ)
explicitU_static.lib(SMAUXpU_XP_IF.obj) : error LNK2019: unresolved external symbol __imp_getenv referenced in function "void __cdecl SMABasOmniSetSSELevel(void)" (?SMABasOmniSetSSELevel@@YAXXZ)
explicitU_static.lib(SMAUXpU_XP_IF.obj) : error LNK2019: unresolved external symbol __imp__putenv referenced in function "void __cdecl SMABasOmniSetSSELevel(void)" (?SMABasOmniSetSSELevel@@YAXXZ)
explicitU_static.lib(vwave.obj) : error LNK2019: unresolved external symbol memmove referenced in function vwave
explicitU_static.lib(vusdfld_cza.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vusuperelashardmod.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vutrs.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vuviscosity.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vuinter_cza.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vuinteraction.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vumullins.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vusdfld.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vufield.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vugens.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vuhard.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vuinter.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vucreepnetwork.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vuel.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vueos.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vuexpan.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vuamp.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vuanisohyper_inv.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vuanisohyper_strain.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vucharlength.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vfabric.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vfric.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vfric_coef.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vfriction.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vcosimulation0.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vdflux.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vdisp.obj) : error LNK2001: unresolved external symbol memmove
explicitU_static.lib(vdload.obj) : error LNK2001: unresolved external symbol memmove
explicitU.dll : fatal error LNK1120: 4 unresolved externals
Abaqus Error: Problem during linking - Single Precision Abaqus/Explicit User Subroutines.
Begin MFS->SFS and SIM cleanup
6/23/2017 4:36:28 PM
Run SMASimUtility.exe
End MFS->SFS and SIM cleanup
Thank you for any suggestions!
Kirane__Kedar
I have the same error message. Anyone has any ideas on how to fix it? Thank you! Creating library explicitU.lib and object explicitU.exp explicitU_static.lib(SMAUXpU_XP_IF.obj) : error LNK2019: unresolved external symbol __imp_printf referenced in function "void __cdecl SMABasOmniSetSSELevel(void)" (?SMABasOmniSetSSELevel@@YAXXZ) explicitU_static.lib(SMAUXpU_XP_IF.obj) : error LNK2019: unresolved external symbol __imp_getenv referenced in function "void __cdecl SMABasOmniSetSSELevel(void)" (?SMABasOmniSetSSELevel@@YAXXZ) explicitU_static.lib(SMAUXpU_XP_IF.obj) : error LNK2019: unresolved external symbol __imp__putenv referenced in function "void __cdecl SMABasOmniSetSSELevel(void)" (?SMABasOmniSetSSELevel@@YAXXZ) explicitU_static.lib(vwave.obj) : error LNK2019: unresolved external symbol memmove referenced in function vwave explicitU_static.lib(vusdfld_cza.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vusuperelashardmod.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vutrs.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vuviscosity.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vuinter_cza.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vuinteraction.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vumullins.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vusdfld.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vufield.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vugens.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vuhard.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vuinter.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vucreepnetwork.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vuel.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vueos.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vuexpan.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vuamp.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vuanisohyper_inv.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vuanisohyper_strain.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vucharlength.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vfabric.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vfric.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vfric_coef.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vfriction.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vcosimulation0.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vdflux.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vdisp.obj) : error LNK2001: unresolved external symbol memmove explicitU_static.lib(vdload.obj) : error LNK2001: unresolved external symbol memmove explicitU.dll : fatal error LNK1120: 4 unresolved externals Abaqus Error: Problem during linking - Single Precision Abaqus/Explicit User Subroutines. This error may be due to a mismatch in the Abaqus user subroutine arguments. These arguments sometimes change from release to release, so user subroutines used with a previous release of Abaqus may need to be adjusted.
Singh__Ripudaman
Hi ,
I have been trying to link visual studio 2015 with ABAQUS 2018.
I have installed ABAQUS 2018, Visual Studio 2015 and parallel studio 2016.
I have tried linking the Visual studio 2015 with ABAQUS by the following method:
1. Creating two new path in environment variables in control panel.
path A to locate ifort.exe file and B to locate ifortvars.bat file.
A.) C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2016.1.146\windows\bin\intel64
B.) C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2016.1.146\windows\bin
Then i changed the abq2018 command file in C:\SIMULIA\Commands
and edit it to add the command :
@call ifortvars.bat intel64 vs2015
It still is giving me the error that "VISUAL STUDIO 2015 is not installed in this system"
I checked and the visual studio is installed and it works.
Why am i getting the same error?!
mecej4
If the call to ifortvars.bat is not positioned before the Abaqus batch command that attempts to check for the presence of Visual Studio and Intel Fortran, the check will fail.
A simpler alternative would have been to (i) open an IFort command window from the Start menu, and then (ii) run the original Abaqus batch file (i.e., the batch file installed as part of Abaqus, not your modified version).
Few of the members of this forum use Abaqus, so you will be better off asking such questions in an Abaqus users forum.
Singh__Ripudaman
Respected
this is the old abq2018 command file in C:\SIMULIA\Commands:
@echo off
setlocal
set ABA_COMMAND=%~nx0
set ABA_COMMAND_FULL=%~f0
"C:\SIMULIA\CAE\2018\win_b64\code\bin\ABQLauncher.exe" %*
endlocal
this command was changed to :
@echo off
setlocal
endlocal
I checked and the visual studio 2015 is installed.
Greg_T_
Hi Ripudaman,
I have success running Abaqus with user subroutines from the Intel Fortran command window.  As mecej4 suggests, open the Intel Fortran command window from the Start menu to initialize the needed environment variables:
     Start -> Intel Parallel Studio XE ... -> Compiler ... for Intel 64
(the ... indicate I've left out specific version numbers such as 2018 or 2019, and use the 64-bit command window to match with Abaqus)
This should be easier than the approach you have described.  I have found that I do not need to run the abaqus initialization from the Intel Fortran command window.  I can enter the abaqus command syntax in the Intel Fortran command window to start the abaqus job with a user subroutine.  Have you tried this approach?
To narrow down your problem to abaqus, have you created a separate main program to call your user subroutine to confirm it compiles and runs?  Running a user subroutine outside of abaqus has helped me to confirm it is working as expected.  I then use it with abaqus and if there are problems there they should be related to abaqus at that point.
Do you have access to the Abaqus knowledge base or to a local support office?
Greg T.
Singh__Ripudaman
Respected Sir,
I tried your approach but it won't work because it is still showing the same error on ABAQUS command window and also on INTEL FORTRAN command window.
I am attaching a screenshot of the error.
it says :
Visual Studio  2015 is not installed on this system.
mecej4
I suspect that the problem was caused by your bracketing the call to ifortvars.bat by SETLOCAL ... ENDLOCAL. The changes made to PATH, etc., in ifortvars.bat will not persist after the ENDLOCAL command has been run.
Greg_T_
Hi Ripudaman,
Your description sounds more like an installation problem to me.  If you can reinstall both Visual Studio and Intel Fortran, that may help.  When installing Visual Studio be sure to install the C++ compiler too.  Install Intel Fortran second so that it will integrate into VS.  I did this just the other day on one of our workstations, and abaqus user subroutines are working as expected.  Hopefully a reinstall will help you too.
If you have access to Abaqus support, that may be the best way to get help to resolve your problem.  The next best source of information may be the on-line SIMULIA Abaqus knowledge base.
Start here: https://www.3ds.com/support/
Then select the "Knowledge Base" link and user your DS login.
Greg T.
