29389 Discussions
how to specific the path where the .mod file will be create to
keweive
as we know, the .mod file will be Created if a source file being compiled defines a Fortran module (MODULE statement).
the .mod file will be in the current path
Can I specify the Path where this file will be ceated to, and How?
thanks for you attention!
Kevin_D_Intel
As documented in the ifort Users guide, use the -module option.
module
Specifies the directory where module files should be placed when created and where they should be searched for.
Syntax
Linux and Mac OS X: -module path
Windows: /module:path
Arguments
path Is the directory for module files.
