Compiling...
main.cpp
Linking...
isortstatic.lib(isort.obj) : error LNK2019: unresolved external symbol _for_emit_diagnostic referenced in function _ISORT
Debug/usoCisortstatic.exe : fatal error LNK1120: 1 unresolved externals
I have read in IVF8 User guide that <
I have used this calling extern "C" void ISORT(int * ia, int * n, int * iperm);
Onlydll version is working fine.
thank you, Guido
Message Edited by sblionel on 05-18-2004 09:18 AM
Thank you for your comment.
I have just tried to insert in Properties->Linker->Additional Library directory the path "C:ProgrammiIntelFortrancompiler80IA32LIB".
But the compiler 's answer is the same:
LINK : fatal error LNK1104: cannot open file 'libirc.lib'
Then I added tis last lib but I gotmany errors such:
Linking...
libifcore.lib(for_get.obj) : error LNK2019: unresolved external symbol __qw32used referenced in function _for__get_su
libifcore.lib(for_exit.obj) : error LNK2001: unresolved external symbol __qw32used
libifcore.lib(for_close_proc.obj) : error LNK2019: unresolved external symbol __qw32used referenced in function _for__close_proc
libifcore.lib(for_m_qwin.obj) : error LNK2019: unresolved external symbol __qw32used referenced in function __unit2handle
For checking my problems I attach the projects: static fortran lib, use of static fortran link from fortran (OK), use of static fortran lib from c++.
Thank you again,
Guido
Message Edited by guido.lombardi@polito.it on 05-18-2004 06:42 AM
Ok, let's try it this way.
In the Fortran project, right click on the project, select Properties, Fortran, Libraries. Change "Disable default library Search Rules" to "No".
In Tools..Options..Projects..VC++ Directories..Library Files, add the path to the Fortran IA32LIB folder I mentioned above.
Rebuild the Fortran project and then the C project.
Thank you very much for the solution! I 'd like to ask you few details on this operation.
This is a "permanent" modification to VS.net envaironment because it is a project's option: Is this additctional path influencing the normal functionalities of VS.NET?
Thank you again,
Guido
Final question:
why does it fail to insert in project property Properties->Linker->Additional Library the directory "C:ProgrammiIntelFortrancompiler80IA32LIB" instead of Tools..Options..Projects..VC++ Directories..Library Files?
Is this a VS.NET bug?
thank you again for your useful support,
Guido
Greatidea! New details on the user guide will be very useful,
bye,
Guido
