29279 Discussions
howto to call IVF8 static library from VS.c++NET
guido_lombardi
As I did with VS C++ 6 and digital visual fortran 5, I have added the .lib fortran taic library to a C++ project using IVF8and VS.c++NET.
It does not work and I got the following error.
Deleting intermediate files and output files for project 'usoCisortstatic', configuration 'Debug|Win32'.
Compiling...
main.cpp
Linking...
isortstatic.lib(isort.obj) : error LNK2019: unresolved external symbol _for_emit_diagnostic referenced in function _ISORT
Debug/usoCisortstatic.exe : fatal error LNK1120: 1 unresolved externals
I have read in IVF8 User guide that <> Thus, it is not possible to link static IVF8 library in VS C++ .NET project?
I have used this calling extern "C" void ISORT(int * ia, int * n, int * iperm);
Onlydll version is working fine.
thank you, Guido
In IVF, the default when building a static library project is to not insert into the object code linker directives that name the Fortran libraries to be used - this is done to prevent problems when these libraries are used with varying project types. So you will have to name the libraries explicitly - libifcore.lib is the one you want - I don't think you'll need others.
The easiest way to handle this is to add libifcore.lib (find it in Program FilesIntelFortrancompiler80ia32lib) to your C++ project files. An alternative is to name it in the "additional modules" list in the Linker project properties - if you don't give the full path, you will have to add the path to the Fortran libraries under Tools..Options..Projects..C++ Directories..Library Files.
Message Edited by sblionel on 05-18-2004 09:18 AM
guido_lombardi
Thank you for your comment.
I have just tried to insert in Properties->Linker->Additional Library directory the path "C:ProgrammiIntelFortrancompiler80IA32LIB".
But the compiler 's answer is the same:
I have tried to add libfcore.lib but now the answer is:
LINK : fatal error LNK1104: cannot open file 'libirc.lib'
Then I added tis last lib but I gotmany errors such:
Linking...
libifcore.lib(for_get.obj) : error LNK2019: unresolved external symbol __qw32used referenced in function _for__get_su
libifcore.lib(for_exit.obj) : error LNK2001: unresolved external symbol __qw32used
libifcore.lib(for_close_proc.obj) : error LNK2019: unresolved external symbol __qw32used referenced in function _for__close_proc
libifcore.lib(for_m_qwin.obj) : error LNK2019: unresolved external symbol __qw32used referenced in function __unit2handle
For checking my problems I attach the projects: static fortran lib, use of static fortran link from fortran (OK), use of static fortran lib from c++.
Thank you again,
Guido
Message Edited by guido.lombardi@polito.it on 05-18-2004 06:42 AM
Ok, let's try it this way.
In the Fortran project, right click on the project, select Properties, Fortran, Libraries. Change "Disable default library Search Rules" to "No".
In Tools..Options..Projects..VC++ Directories..Library Files, add the path to the Fortran IA32LIB folder I mentioned above.
Rebuild the Fortran project and then the C project.
guido_lombardi
Thank you very much for the solution! I 'd like to ask you few details on this operation.
This is a "permanent" modification to VS.net envaironment because it is a project's option: Is this additctional path influencing the normal functionalities of VS.NET?
Thank you again,
Guido
The Tools..Options change is harmless to VC++ - it simply makes the Intel Fortran libraries visible to projects that need it.
guido_lombardi
Final question:
why does it fail to insert in project property Properties->Linker->Additional Library the directory "C:ProgrammiIntelFortrancompiler80IA32LIB" instead of Tools..Options..Projects..VC++ Directories..Library Files?
Is this a VS.NET bug?
thank you again for your useful support,
Guido
I'm not sure what the "it" refers to here. The Intel Fortran install isn't allowed to modify the VC++ settings. I do feel we could improve the documentation in this area, as it is more complex than it was under CVF.
guido_lombardi
Greatidea! New details on the user guide will be very useful,
bye,
Guido
