29282 Discussions
icc/ifort compile time increases after firewall install
tetabiate
a few days ago I declared new firewall rules on my desktop Linux machine in order to block most of the incoming/outgoing TCP/IP packets and now the compile time of icc/ifort has increased significatively. Do the compilers need access to a specific TCP/UDP port or do they "phone home"?
If so, what is the port number or IP address?
Thanks in advance for your response.
The compilers do not "phone home". They do look for a license server on your network if configured to do so (either the license file names a server or your INTEL_LICENSE_FILE environment variable points to one or more license servers on your network.
We've seen this before with customers who had moved a license server or taken one out of service without updating the license file or environment variable.
It can also happen if you're using FLEXlm licensing for non-Intel products and have a non-existent server in the server path.
tetabiate
Thank you very much Steve. It seems our FLEXlm license server is having problems. I did a quick test using LM_LICENSE_FILE='' and everything works fine.
