idb crashed while starting
Li_Dong
I am using Intel Fortran Compiler 11.0.074. When I started idb, the main window just flashed and quitted with the error message
JVM terminated. Exit code=1
/opt/java/jre/bin/java
-jar /opt/intel/Compiler/11.0/074/idb/gui/ia32/startup.jar
-os linux
-ws gtk
-arch x86
-launcher /opt/intel/Compiler/11.0/074/idb/gui/ia32/dbggui
-name Dbggui
-showsplash 600
-exitdata 190004
-gui
-vm /opt/java/jre/bin/java
-vmargs
PS: the output of "java -version" is
java version "1.6.0_10"
Java SE Runtime Environment (build 1.6.0_10-b33)
Java HotSpot Server VM (build 11.0-b15, mixed mode)
Thanks for helping!
Li_Dong
I found idb works normally when I start it as root! It must be some priviledge problem. What can I do?
TimP
Quoting - dong_li_1985
For all files in the java installation, group and other should have the same read and execute permissions as root. I had to remove all out of date java versions which were visible to package manager.
