idb: libpostoffice
roddur
libPostoffice.so is not activated when calling idb either by "source"ing ifortvars or idbvars.
the only way is export the file in LD_LIBRARY_PATH.
why?
Hubert_H_Intel
Quoting - roddur
why?
The only thing you need to do is to source the compiler script iccvars.(c)sh or ifortvars.(c)sh which sets up all compiler, debugger and libraries environment variables. All required runtime libs are then included in LD_LIBRARY_PATH.
E.g.:
$ source /opt/intel/Compiler/11.1/059/bin/iccvars.sh ia32
$icc -V
Intel C Compiler Professional for applications running on IA-32, Version 11.1 Build 20091012 Package ID: l_cproc_p_11.1.059
Copyright (C) 1985-2009 Intel Corporation. All rights reserved.
$ idbc -version
Intel Debugger for applications running on IA-32, Version 11.1, Build [1.2097.2.295]
It seems it's an older version you are using since libPostoffice.so is no longer included with the Compiler
How did you notice that libPostoffice.so is missing and required for using idb?
Hubert.
TimP
Checking earlier posts, I find libPostoffice mentioned only in connection with the one Intel64 compiler version where libraries required for idb were omitted. So you should look to see if you are using that version.
Kevin_D_Intel
Its an earlier 11.0 defect; the earlier post is (here). DPD200110439. Its visible via ldd or iidb:
$ iidb
iidb: error while loading shared libraries: libPostOffice.so: cannot open shared object file: No such file or directory
roddur
Not really, as you can see:
in my bashrc, i have:
# User specific aliases and functions
source /opt/intel/Compiler/11.1/056/bin/ifortvars.sh ia32
$ which ifort
/opt/intel/Compiler/11.1/056/bin/ia32/ifort
$ ifort --version
ifort (IFORT) 11.1 20090827
$ uname -a
Linux roddur 2.6.30.9-90.fc11.i686.PAE #1 SMP Sat Oct 17 11:24:32 EDT 2009 i686 i686 i386 GNU/Linux
$ iidb
It may be caused by the fact that fc11 not supported fully, but what is more confusing is if I simply put
$ export LD_LIBRARY_PATH=/opt/intel/Compiler/11.1/056/idb/lib/ia32/
it works fine, suggesting idb/lib is not activated by ifortvars.
$ iidb
Intel Debugger for applications running on IA-32, Version 11.1, Build [1.2097.2.270]
FOR NON-COMMERCIAL USE ONLY
(idb) q
Hubert_H_Intel
$ iidb
You should call the debugger by it's driver start script idb only, not the debugger executable iidb. This sets the library paths correctly.
E.g.:
-bash-3.1$ source /opt/intel/Compiler/11.1/059/bin/ifortvars.sh intel64
-bash-3.1$ iidb
-bash-3.1$ idb
and the idb starts.
Hubert.
