oh_moose,
Often a program (your program) will contain defensive code (what are commonly called sanity checks).
IF(something wrong) STOP
Often a program written in haste will omit sanity checks
ALLOCATE(ARRAY(nElements))
Which abort during allocaiton
With defensive code
ALLOCATE(ARRAY(nElements), STAT=iErr)
IF(iErr .NE. 0) STOP
This is good practice. However, as you observed, issuing a STOP is not productive in debugging software errors.
What I prefer to do is to replace the STOP with a call to asubroutine named DOSTOP and which takes an argument.
IF(iErr .NE. 0) CALL DOSTOP('FileName - Memory Allocation Error')
And where
SUBROUTINE DOSTOP(CVAR)
USE YourIoMod
CHARACTER*(*) CVAR
WRITE(IOUERR,*) CVAR
WRITE(*,*) CVAR
! place break point here
STOP 'DOSTOP'
RETURN
END SUBROUTINE DOSTOP
Compile even the release version with debug information but compile DOSTOP without optimizations. DOSTOP is used in all versions.
When break occures you can examine variables and call stack. When you locate where the error came from and if due to optimizations you are unable to determine the cause of the problem then you can recompile the file (which produced or detected the error) with optimizations off. Then re-run to reproduce the error. Work your way out and back to the source of the problem. Once found and corrected, you can re-optimize those files again.
Note, if the error is potentially correctible you can place the "Next Statemen" at the RETURN then step out of the DOSTOP. Once in the calling subroutine you can move the "Next Statement" in an attempt to follow the programming sequence that caused the error.
Jim Dempsey
Happy New Year to you and everybody else here.
My software was written for VMS and now I am trying to make it work on Linux. I do use services like LIB$SIGNAL and LIB$STOP (if you are familiar with those) and have plenty of consistency checks in my source code. A microsecond spent on those checks saves me hours of debugging. I have a full implementation of these two VMS services for Linux (including a Message utility for VMS-style .MSG files, if someone is interested). It would be nice to have access to the ifort traceback routine (missing documentation). It would be even better to have the debugger stop the program at the right point. But the primitive Linux "backtrace" works as temporary hack for now and I can easily set a break point at LIB$STOP. That is not the problem.
The problem occurs when the Fortran RTL decides to end the program. On a VMS system at least I get the traceback and know where it happens. With the VMS debugger I may even have access to various variables (if they are not optimized away - hello, seen that gem before?).
Oh_moose,
Welcome back,
Most internal IVF errors are echoed to the "console". If you run as a console application then the error messages would tend to hang around for you to read. If your application is windowed (non-console) then the message may end up in NULL. I believe you can set an environment variable to indicate a file name for an IOUNIT. You should be able to route the "console" output to a file for your review after the program takes a dive. If setting environment variables:
FOR_PRINT is stdout - write(*,f) iolistandprint f,iolist
FOR_TYPE is stdout - type f,iolist
FORT0 is stderr - write(0,f) iolist
FORT6 is stdout - write(6,f,) iolist
Depending on what the author used, one of those should have the error message. Hopefuly the author writes some message instead of simply stopping with an error number.
Jim Dempsey
Also
STOP produces a call to "_for_stop_core". So you could potentially place a break point there. Don't quite know what DLL is going to do. You may also have to look at the other exit/abort/terminate library function calls and place break points on those as well.
Jim Dempsey
Setting a breakpoint at for_stop_core looks a useful workaround (without a leading underscore here, good! and hey, DLL is Windows;-). I assume this is a routine which the Fortran RTL calls to execute a Fortran STOP statement. But this does not help if the Fortran RTL detects a problem and ends the program (no STOP involved here).
I tried to set a break point at "exit" (unix exit that is). Good thinking, Jim. However, the first time I got no useful traceback and all variables where optimized away. I have not managed to repeat this since the debugger keeps crashing. Maybe the debugger tells me to get a break.
Steve, you know how the VMS debugger works. That is what I want.
My advice for this situation, which I think I have offered before, is to write your own "stop" routine which you call instead of using stop directly. Then set a breakpoint on the routine. That routine could even call TRACEBACKQQ to issue a traceback. I do not recommend trying to set breakpoints on the library routines.
For a program that ends with an exception, I suggest you look at the SIGNALQQ library routine to see if this helps.
%FOR-E-OUTCONERR, output conversion error
(or something more serious which would eventually cause an end of the program execution)
and then you examine the corresponding expression.
Why would a self-written "stop" routine help in situations where the Fortran RTL ends the program with a message like "Process has exited with status 114"?
TRACEBACKQQ looks interesting. For the sake of completeness, in case someone else searches for this features and ends up here, I found the following web page contains some useful information.
http://www.intel.com/software/products/compilers/flin/docs/main_for/mergedProjects/bldaps_for/error_handling_ovw.htm
A break point at SINGALQQ does not intercept the exception "Process has exited with status 114". The program simply ends and the debugger does not show me where it ended, not to mention the lack of access to any variables since the program does not run anymore.
My mention of SIGNALQQ was NOT to suggest that you set a breakpoint on it - that will do no good at all. Rather, SIGNALQQ is how you can supply your own exception handler, similar to LIB$ESTABLISH on VMS, though it is a "global" handler (like VMS vectored handlers) and not stack-frame based like VMS.
If you simply get a "process has exited" message, then either the program returned from the main program or something else unusual happened which bypassed the normal control mechanisms.
Problem solved.
For my Linux implementation of LIB$SIGNAL I am going to add a bit of assembler code to check if the program runs under the control of the debugger and then perform an Int 3 to transfer control to the debugger for warnings, errors and fatal messages.
Thanks for reading my mind regarding LIB$ESTABLISH. I will need soon.
