ieee real(16) support
dave_frank
Now that ieee has defined what real(16) format is, will Intel provide future support?
Dave,
Intel Fortran has provided IEEE-style REAL(16) support for at least a couple of years now.
Steve
dave_frank
Amazing since the format is still in draft form.
Sooo you are saying you guys guessed right a couple years
ago and are using the draft format's 15-bits exponent and 112-bits fraction?
Dave,
I can't readily find a description of the IEEE effort here (even on the IEEE web site), so can't verify the details. But I can tell you that vendor support for an "IEEE-style" 128-bit floating format, with 15-bit exponent and 112-bit fraction, has been available in most high-end platforms for more than a decade. Digital supported this format on Alpha processors in 1993 (and had a similar VAX format dating back to 1980.)
In Windows Fortran compilers, Intel Fortran is one of several that currently support this format - CVF is not among them, though the future Intel Visual Fortran will be.
Steve
TimP
As Steve points out, DEC and HP supported this format 10 years ago. It is IEEE-854 compliant, and those Windows compilers (not only Intel's), which support real*16, use the same format. It could have been difficult for IEEE to persuade people to change horses. No, I didn't know about that meeting.
Other major vendors who support real*16 on their own architectures (e.g. IBM and SGI) have a non-IEEE compliant format with 11-bit exponent and 107 bit precision. When I last compared them, neither SGI's nor HP's transcendental functions took advantage of the full precision of their floating point format, apparently favoring speed over accuracy. Speed also favors those non-standard IBM and SGI implementations over the software floating point real*16 employed on many systems.
