29282 Discussions
if ifort 11.1 supports Fortran 2003
pcfresher
Hi, there
I wonder if ifort 11.1 supports Fortran 2003. For example, I tried to compile the following module file on a supercomputer with ifort 11.1:
module proc_component_example
type t
real :: a
procedure(print_me), pointer, nopass :: proc
end type t
contains
subroutine print_me (arg)
type(t), intent(in) :: arg
write (6,*) arg%a
end subroutine print_me
subroutine print_my_square (arg)
write (6,*) arg%a**2
end subroutine print_my_square
end module proc_component_example
but with error message:
test_mod.F90(9): internal error: Please visit 'http://www.intel.com/software/products/support' for assistance.
write (6,*) arg%a
does it mean I can not use procedure pointers in derived type?
TimP
Quoting - pcfresher
write (6,*) arg%a
There shouldn't be such a failure in the current version.
Steven_L_Intel1
Intel Fortran 11.1 supports most of Fortran 2003, including procedure pointers, but not everything. As Tim says, your source compiles, at least with default options, in the current update 2 (11.1.056).
If you use a feature the compiler doesn't support, you should get a clear error message and not an internal compiler error.
pcfresher
Thanks to Tim and Steve. The example is simply copied from "The Fortran 2003 Handbook", page 88. The compiler I used seems to be version 11.1.038, the processor is Intel Xeon CPU.
This morning, I commented the "write" clause in these two subroutines, and compiled using "ifort -c", but with the following error:
gem__lo_decode_locator: locator line sequence number out of range: catastrophic error: **Internal compiler error: abort signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for test_mod.F90 (code 3)
do you have any idea? thank you so much!
Kevin_D_Intel
The source change has simply aggravated another variant of internal compiler error in the earlier 11.1.038 compiler you are using. Both internal errors are fixed in thelatest 11.1 update 2 (11.1.056) so please upgrade to the newer compiler to avoid these.
pcfresher
Thank you, Kevin. I will ask the administrator if it is possible to upgrade to the new version. Thank you!
