if(present(present))... no reserved words in Fortran
Norman_K_
I wish to make it clear that I am not recommending the following, but I think it should compile and run, see error messages attached
program TEST_PRESENT
implicit none
call TEST_PRESENT_check
stop
contains
subroutine TEST_PRESENT_check(present)
logical, optional, intent(out) :: present
if(present(present)) present = .true.
end subroutine TEST_PRESENT_check
end program TEST_PRESENT
! Output:
!1>Compiling with Intel(R) Visual Fortran Compiler 19.1.1.216 [IA-32]...
!1>test_present.f90
!1>...\test_present.f90(8): error #6410: This name has not been declared as an array or a function.   [PRESENT]
!1>...\test_present.f90(8): error #6341: A logical data type is required in this context.   [PRESENT]
!1>compilation aborted for ...\test_present.f90 (code 1)
!1>
!1>Compiling with Intel(R) Visual Fortran Compiler 19.1.1.216 [Intel(R) 64]...
!1>test_present.f90
!1>
Steve_Lionel
Gilles has it exactly right. Fortran has no reserved words and you can redeclare all of the intrinsics. By declaring PRESENT as a dummy argument, that hides the intrinsic.
GVautier
New Contributor III
I think it's normal. you declare a "present" variable so the external "present" function is not seen anymore.
Steve_Lionel
Norman_K_
Dear Both
I had not realised that was a "feature", and makes me wonder about other examples, but where a syntax error does not result.
Thanks for your responses.
N
Steve_Lionel
You might enjoy this, then. Nowadays the compiler will grumble, but it serves to illustrate how confusing things can get if you try. This was written by Stan Rabinowitz at DEC in the 1980s, and a lot of it is non-standard, but it's amusing nonetheless.
	program segment
C
C
C
	IMPLICIT INTEGER *2(O), LOGICAL(T-U)
	COMMON//		UNCOMMON//		COMMON
	      INTEGER			FLOATING_POINT
	      REAL			IMAGINARY
	      COMPLEX			SIMPLE
	INTRINSIC EXIT
	EXTERN	  ALL,SOME,NONE
	SAVE	  NOW
	DOUBLE PRECISION A = 3
	ASSIGN 3 TOO THREE
3	FORMAT((()))
	IF (THEN) THEN
	END IF
	E
     1   N
     2    D
	DOUBLE  COMPLEX FUNCTION FN(ARG1,DOUBLE FN,DOUBLE)
	COMPLEX DOUBLE  FN(ARG1)
	DIMENSION DOUBLE(-8:-7,-6:*)
	VIRTUAL STORAGE(8/7)
	COMPLEX*1	6MEN_IN_A_BOAT, THEN THERE WERE 5
	UNLOCK THE DOOR
	IF (1) 2,3,4
4	IF (4HCLUB) 37, 6, 5
    5	DO 37 I=1.5
	CALL F(04*05,*06)
37	CONTINUE
 6	STOP '4X'
2	A='4X'
 3	A='4'X
	DELETE (3)
	INSANITY=%LOC(1.2D5)
	RETURN
	END
	SUB  ROUTINE FORMAT(*)
	REAL ROUTINE ______
	REAL(ROUTINE)=1E1
	DO WHILE (1 .NEQV. 2)
	READ(ERR=7,UNIT=7)
123	READ(3'X)
456	READ *,X
*89	READ(UNIT=*,X)
777	READ UNIT=9
	ENDDO
007	CALL FRAME(A ONE, &2, AND A 3)
2	Q=3Q1
	ENTRYST(Z 9)
	RETURN
	71
	END
	REAL*4 ROUTINE TRICKY
	END
	IMPLICIT INTEGER*4(X), INTEGER*2(O-Q)
	DIMENSIONLESS VAR(1**1)
	BYTE BYTE
     0	DO 1, I=2,3
100	FORMAT(I7.4,Z8.2,G5.2e4,2p/TL7Q:$!L1,B12.9,J6
     X		SPSSBZQX'garbage')
101	FORMAT(<(1,2)>I)
102	FORMAT(L<I3(I4/'ABC')>)
10 3	FORMAT(I)
1	CONTINUE
	X=3
	DATA X/4/
	GOTO 42
43	DO 44 I=1,9,-3
42	IF (I) 43,44,45
44	END IF 		= 9
45	I will bet you $25 that 4=2+3.
	ASSIGN 100 TO QTEST
	GO TOPLESS!
	E N D
	CHARACTER*8 FUNCTION CHOMP(A,B,C,D,E,STAR)
	DIMENSION B(C:D,0:0,0:0,0:0,0:0,0:00,0:0)
	COMMON /PQRST/ UVWX,YZ  // L
	REAL REAL(3.14159D4)
  !	really?
	CHARACTER*(*) STAR(*)
	BYTE E(65537+L*A/9-1)
	STAR(1)(2:3)=CHOMP//'FOOD'
	REAL(3.14159)=----++++----0
	WRITE(A,B) ((1,2),J=3,4,5)
	WRITE(9,*) WRITE(B,A)
007	MIN=.FALSE. .XOR. .NOT    ..1.    EQ .03   .AND.  .NOT.  .NOT.   NOT.
	STOP
	END
	BLOCK data
	IMPLICIT NONE
	COMPLEX*16 C
	INTEGER ARRAY(35)
	REAL R
	COMMON /WOW/ R,ARRAY
	EQUIVALENCE (R,C)
	DATA (ARRAY(I),I=1,5)/5*7/
	END
	END
	END
C	This is finally the end of this absurdity.
Norman_K_
Dear Steve,
That is just wonderful; perhaps too much for a T shirt or a gravestone, but certainly worthy of framing and displaying in a home office, now where did I put that pile of fanfold?
Norman
jimdempseyatthecove
>>This was written by Stan Rabinowitz at DEC in the 1980s...
Great guy, Stan. I worked with him in the 1970's in building 12 at DEC in Maynard.
Jim Dempsey
