ifc libraryies incomplete on x86-64
TimP
Sorin:
Yes, a few functions which may be linked by ifc are taken from libraries supplied by your system. This would produce your failure, if your system has only x86-64 versions of those libraries. You may have to figure out which libraries those are, and keep versions e.g. from 32-bit SuSE in a directory against which ifc will link. In the past, I have seen ifc builds require libc.a, libg2c.a, or libgcc.a, or specific .o files from those libraries. Supplying additional diagnostic options to ifc for the link step should help you to determine which libraries are failing, e.g.
ifc -#
