29427 Discussions
ifort 16.0.0.109 compilation fails with -static
karin_m_
I am trying to compile with -static; however this fails at the load stage even for the simplest little program (omitting -static works fine)
print *,'hello'
end
ifort -static hello.f90
gives the following error messages
ld: cannot find -lm
ld: cannot find -lpthread
ld: cannot find -lc
ld: cannot find -ldl
ld: cannot find -lc
where do these come from? I have source'd ifortvars.sh, compilervars.sh and mklvars.sh so all environment variables should be set correctly. The current installation is an update from a previous version - could it be that there is something which ought to have been deleted but hasn't (AFAIK -pthread is depreciated in the current version); if so what?
Linux Custer 3.10.0-229.11.1.el7.x86_64 #1 SMP Thu Aug 6 01:06:18 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0.0.109 Build 20150815
TimP
You would need to install those static libraries usèd by your gcc. If you want to specify only the ifort provided static libraries, set -static-intel
TimP
karin_m_
Ahhh! Brilliant - got system administrator to reinstall *.a libraries which had somehow disappeared. that fixed it, thank you!
