ifort 16 ICE: -debug full -O2
AShte
newblue4> ifort -coarray ca_check1.f90
newblue4> ifort -coarray -debug full -O2 ca_check1.f90
010101_0
catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for ca_check1.f90 (code 1)
newblue4>
newblue4> cat ca_check1.f90
program z
use iso_fortran_env
implicit none
integer, parameter :: dp = real64
real( kind=dp)     :: time1, time2
integer :: x(10)
  • , img, nimgs, i
      img = this_image()
    nimgs = num_images()
        x = img
  • sync all
    if ( img .eq. 1 ) then
      do i = 2, nimgs
    !    time1 = mytime()
    !    x = x(:)
    !    time2 = mytime()
    !    write (*,"(a,g)") "Remote read took, s : ", time2-time1
        time1 = mytime()
        x(:) = x
        time2 = mytime()
        write( *,*) "Remote write took, s : ", time2-time1
        write( *, "(a,i0,a,10(i0))" ) "img: ", i, "x:", x(:)
      end do
    end if
    sync all
    write (*,"(a,i0,a,i0,a)") "Image: ", img, " out of ", nimgs, &
     " completed ok"
    contains
    function mytime() result (tseconds)
            real( dp ) :: tseconds
      integer( INT64 ) :: tsec, trate
      CALL SYSTEM_CLOCK( count=tsec, count_rate=trate )
      tseconds = real(tsec,kind=dp) / real(trate,kind=dp)
    end function mytime
    end program z
    newblue4>
    Anton
    Please show the output of:
    ifort -V
    Never mind - I can reproduce this now. Taking off -debug is a workaround.
    AShte
    Steve, thank you for looking into this.
    In case you still want it:
     ifort -V
    Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0.0.109 Build 20150815
    Escalated as issue DPD200382002. I find that if I try our latest internal sources, for the next major release later this year, I don't get the error. I have asked the developers to take a closer look to see if they can identify the problem.
    I would recommend updating to 16.0.2, available now.
    The fix was identified, it will be in the next major release but not a 16.0 update.
