29249 Discussions
ifort: Command line warning: no action performed for specified file(s)
bnduncan
I've compiled my code under RedHat Linux and IFC V8. All my .o files are created, but I'm getting the following error when the executable is under creation:
and no executable is created. I get no other warning messages or errors. Can you offer advice on how to diagnose this problem???
What is the ifort command line you are using?
bnduncan
Here is the command line and error when I try to create the executable:
ifort -cpp -w -c -O2 -Vaxlib -auto -noalign bpch2_mod.o diag_mod.o dao_mod.o time_mod.o biofuel_mod.o biomass_mod.o comode_mod.o dao_read_mod.o geia_mod.o global_oh_mod.o tagged_co_mod.o wetscav_mod.o CO_strat_pl.o TRBDIF.o VTRI0.o airemiss.o airmas.o alloc_err.o anthroems.o arsl1k.o backsub.o biofit.o boxvl.o calcrate.o check_stt.o chem.o chemRnPbBe.o chemch3i.o chemdr.o chemhcn.o chemo3.o chemset.o cleanup.o close_files.o cntmat.o compute_f.o compute_l2g.o convert_units.o copytxt.o cosa.o cosc.o cossza.o cstrip.o decomp.o depvel.o diag1.o diag20.o diag3.o diag41.o diag48.o diag49.o diag5.o diag50.o diag51.o diag7.o diag_2pm.o diag_flux.o diagoh.o diagpl.o diffg.o diffuse.o drydep.o drydepRnPbBe.o drydep_setup.o dryflx.o dryflxRnPbBe.o e_ice.o emf_scale.o emfossil.o emisop.o emissRnPbBe.o emissch3i.o emissdr.o emisshcn.o emlightning.o emmonot.o faltbl.o fct3d.o fertadd.o filew.o fillfields.o fillstr.o filns.o findmon.o flashes.o fxppm.o fyppm.o fyrno3.o fzppm.o getalt.o getifsun.o getprt.o hilo.o hilo3D.o hpsort_int.o humeff.o hunt.o ijpch.o ijscal.o ijscal_2pm.o init_scav.o initgas.o initialize.o inito3.o inptr.o input.o ioerror.o jsparse.o lightdist.o lightning.o lmtppm.o lump.o make_restart_file.o make_rh.o metero.o modin.o ndxx_setup.o nfcldmx.o o3comp.o ohsave.o open_ch3i_files.o open_files.o optdepth.o paftop.o paftop2.o partition.o pderiv.o physproc.o plsave.o precipfrac.o pulsing.o qckxyz.o rainout.o ratcons.o rdaerosol.o rddrycf.o rdisopt.o rdlai.o rdland.o rdlight.o rdmonot.o rdsoil.o rdust.o read49.o read_restart_file.o read_tindex.o read_tropopause.o read_uvalbedo.o readair.o reader.o readfields.o readlai.o ruralbox.o schem.o setbase.o setcloud.o setemdep.o setemis.o setjfam.o setmodel.o setnfam.o setpl.o settrace.o setup.o sfcwindsqr.o slq.o smvgear.o soilbase.o soilcrf.o soilnoxems.o soiltemp.o soiltype.o subfun.o sunparam.o tcorr.o tpcore.o main.o trace0.o tracerid.o tranuc.o tropopause.o turbday.o txt2inum.o txtext.o upbdflx_noy.o upbdflx_o3.o washout.o wetdep.o write20.o write49.o xadv.o xltmmp.o xmist.o xtp.o ymist.o ytp.o linux_err.o AerosolOH.o CO_budget.o CO_decay.o CO_fillfields.o CO_fromHCs.o CO_ohsave.o CO_readfields.o CO_readfields2.o CO_strat.o OHparam.o avgavgw.o avgrefl.o avgtp.o calc_oh.o chemco.o clean.o cleanisop.o donefunctions01.o donefunctions02.o donefunctions03.o donefunctions04.o donefunctions05.o donefunctions06.o donefunctions07.o donefunctions08.o donefunctions09.o donefunctions10.o donefunctions11.o donefunctions12.o donefunctions13.o donefunctions14.o donefunctions15.o donefunctions16.o donefunctions17.o donefunctions18.o donefunctions19.o donefunctions20.o donefunctions21.o donefunctions22.o donefunctions23.o donefunctions24.o donefunctions25.o donefunctions26.o donefunctions27.o donefunctions28.o donefunctions29.o donefunctions30.o donefunctions31.o donefunctions32.o donefunctions33.o donefunctions34.o donefunctions35.o donefunctions36.o emissco.o func_ifs.o get_refl.o getinfo.o getoh.o hipolluted.o interpOH.o correctOH.o correctOH2.o modpolluted.o paramA.o paramB.o paramC.o paramD.o paramE.o paramF.o polint.o read_COPminusL.o read_O3clim.o read_TOMSO3.o read_coeff.o read_dustrat.o readavgOH.o readavgOH2.o read_correction.o readOH94.o remote.o skip.o sumup.o findxsect.o funbas.o funo1dham2.o gettoto3.o jvaluein.o jvalueinhcn.o matinv.o numair.o numo3.o readcs.o readcshcn.o rtfunc.o scattr.o sol.o -o geosco
You've specified, as far as I can tell, all object files, yet told the compiler not to invoke the linker (-c). What did you expect it to do?
Remove the -c. That tells ifort to compile only and not link.
