option -save doesn't work well with arrays
ifort version: (ifort -V)
Intel Fortran Compiler Professional for applications running on IA-32,
Version 11.1 Build 20090827 Package ID: l_cprof_p_11.1.056
(ifort -what)
Intel Fortran 11.1-2582
See the following example with two simple fortran source files:
file #1: savetest.f
[fxfortran]c main program: test option -save program savetest implicit none real sub_in(2) real sub_out(5) integer i do i=1,31 sub_in(1)=real(i) sub_in(2)=real(mod(i,2)) call sub_sub(sub_in,sub_out) c output on screen if(i.lt.6 .or. i.gt.25) then print'(i3,'' iframe='',f4.0,'' delayh:'',2f6.2,'' ...''2f6.2)' & ,i,sub_out endif if(i.eq.6 ) print'('' .....'')' enddo end [/fxfortran]
file #2: sub_sub.f
[fxfortran]c shift values in array delayh every second call subroutine sub_sub(rinp,rout) implicit none integer dim c dim=13 works !!! parameter (dim=14) real rinp(*),rout(*),delayh(dim) integer iframe,i #ifdef SAVE_DELAY save #endif c first call: set default values in array delayh if(rinp(1).eq.1.0) then do i=1,dim delayh(i)=-0.01*i enddo iframe=0 endif if (iframe .eq. 0) then iframe = 1 do i = 1,dim-1 delayh(i) = delayh(i+1) end do delayh(dim) = rinp(1) else iframe = 0 end if rout(1)=real(iframe) rout(2)=delayh(1) rout(3)=delayh(2) rout(4)=delayh(dim-1) rout(5)=delayh(dim) end [/fxfortran]
Result when compiling and running WITH explicit save ("-DSAVE_DELAY"): OK
[bash]ifort -fpp -zero -save -CB -c savetest.f ifort -fpp -zero -save -CB -DSAVE_DELAY -c sub_sub.f ifort savetest.o sub_sub.o -o comp_test_1 comp_test_1 [/bash]
1 iframe= 1. delayh: -0.02 -0.03 ... -0.14 1.00
2 iframe= 0. delayh: -0.02 -0.03 ... -0.14 1.00
3 iframe= 1. delayh: -0.03 -0.04 ... 1.00 3.00
4 iframe= 0. delayh: -0.03 -0.04 ... 1.00 3.00
5 iframe= 1. delayh: -0.04 -0.05 ... 3.00 5.00
26 iframe= 0. delayh: -0.14 1.00 ... 23.00 25.00
27 iframe= 1. delayh: 1.00 3.00 ... 25.00 27.00
28 iframe= 0. delayh: 1.00 3.00 ... 25.00 27.00
29 iframe= 1. delayh: 3.00 5.00 ... 27.00 29.00
30 iframe= 0. delayh: 3.00 5.00 ... 27.00 29.00
31 iframe= 1. delayh: 5.00 7.00 ... 29.00 31.00
WRONG result when compiling and running w/o explicit save:
[bash]ifort -fpp -zero -save -CB -c savetest.f ifort -fpp -zero -save -CB -c sub_sub.f ifort savetest.o sub_sub.o -o comp_test comp_test [/bash]
2 iframe= 0. delayh: -0.02 -0.03 ... -0.14 -0.14
3 iframe= 1. delayh: -0.03 -0.04 ... -0.14 3.00
4iframe= 0. delayh: -0.03 -0.04 ... -0.14 -0.14
5 iframe= 1. delayh: -0.04 -0.05 ... -0.14 5.00
26 iframe= 0. delayh: -0.14 -0.14 ... -0.14 -0.14
27 iframe= 1. delayh: -0.14 -0.14 ... -0.14 27.00
28 iframe= 0. delayh: -0.14 -0.14 ... -0.14 -0.14
29 iframe= 1. delayh: -0.14 -0.14 ... -0.14 29.00
30 iframe= 0. delayh: -0.14 -0.14 ... -0.14 -0.14
31 iframe= 1. delayh: -0.14 -0.14 ... -0.14 31.00
The values of array "delayh" are not saved. (:-(
Annotations:
a) This error doesn't appear in my example, when the dimension "dim"
of the array delayh is less than 14
b) This error doesn't appear in ifort-version 8
How can Intel help?
Thank you for the nice reproducer.
The issue occurs when compiling sub_sub.f with both -save and -CB (i.e. -check bounds).
I would not rely on the "good" results you see with dim=13. That occurs only on IA-32 and I'd guess just by chance. On Intel 64, incorrect results occur with both dim=13 and dim=14 and the two options I noted.
Whatever the underlying defect is, it does not exist (on either IA-32 or Intel 64) in our next major release due out in a couple of months. As a work around, with the 11.1 compiler, you can compile without bounds checking until the next major release is available.
I will also direct this to Development to check whether we can fix this in an 11.1 update.
[bash]$ ifort -C -traceback savetest.f sub_sub.F $ ./a.out 1 iframe= 1. delayh: -0.02 -0.03 ... -0.14 1.00 forrtl: severe (193): Run-Time Check Failure. The variable 'sub_sub_$IFRAME' is being used without being defined Image PC Routine Line Source a.out 0808E9BD Unknown Unknown Unknown a.out 0808D7B5 Unknown Unknown Unknown a.out 0805A86F Unknown Unknown Unknown a.out 0804B397 Unknown Unknown Unknown a.out 0804BAD2 Unknown Unknown Unknown a.out 0804A25C sub_sub_ 22 sub_sub.F a.out 08049EEE MAIN__ 12 savetest.f a.out 08049E11 Unknown Unknown Unknown libc.so.6 F760EC0E Unknown Unknown Unknown [/bash]Once you fix the error shown by this run, you will repeat the procedure and obtain a similar message for DELAYH. That's the drawback of dynamic detection.
Even -C by itself will locate this error at runtime, but you will not be told on which line the error happened.
In #1 you wrote The issue occurs when compiling sub_sub.f with both -save and -CB (i.e. -check bounds). I think that -zero should have been added because, without that option, if the subroutine is called with rinp(1) different from 1.0 on the first call to it, iframe would be used uninitialized in Line-21.
Curiously, the compiler bug is not seen if, in addition, either the -g or -O0 option is used.
I didn't mention -zero because it is not in play in relationto the defect being triggered, but I understand/agree with your assessment regarding iframe.
-g implies -O0. Disabling optimization is another work around if one needs -CB while developing the code further. Thanks for noting that.
