29368 Discussions
ifort: command line warning #10006: ignoring unknown option '-qmkl'
Steve_Lionel
Which OS? Which compiler version? Please show a console log of the command and the output.
mecej4
Look up the compiler documentation or run the command ifort /help (Windows) or ifort -help (Linux) to find the correct syntax. On Windows, the option is /Qmkl .
Steve_Lionel
If on Windows you use -qmkl, you get an error that /qmkl (note the slash) was not found. -qmkl is the documented syntax for Linux.
Navdeep_Rana
Hi all,
Sorry for not including relevant information. I am on a linux desktop, where I installed intel-oneapi tools via spack.
Here's the output of ifort --version
ifort (IFORT) 2021.2.0 20210228
Copyright (C) 1985-2021 Intel Corporation. All rights reserved.
When I use the following command
ifort -init=zero,array -qmkl -warn -fpp -Ofast -static -xHost
, I get the error. Replacing -qmkl with -mkl works, but the documentation mentions '-qmkl'.
