29390 Discussions
Fortran Error: The number of subscripts is incorrect
crash1010
Hi! I'm a complete beginner in programming and Fortran. This subroutine is part of a mastermind game where the computer guesses my 4 digit color code (6 colors to chose from) . After the computer guesses a random code the user can input the number of  black sticks (if colors are on the right spot and the right color) and the number of white sticks (if the colors are right but not on the right spot). After compiling this subroutine called 'solve' I got many errors about the matrix where i want to store 0 and 1 (for possible and not possible colour codes). Can anybody help my how to define this matrix and what my errors mean?
Thanks a lot in advance.
Subroutine SOLVE(n, sN, wN, field)
IMPLICIT NONE
INTEGER :: sN, wN, aus, l, k, j, i, n, sB(n), wB(n)
INTEGER, DIMENSION (10,4) :: field
aus = 0          !at the beginning there are 0 eliminated combinations
! this loop goes through every possible colour combination (6x6x6x6)
DO l = 1, 6, 1
   DO k = 1, 6, 1
      DO j = 1, 6, 1
         DO i = 1, 6, 1
            IF (n == 1) THEN  !in the first round n of the game every combination is         still possible therefore the matrix A should be set to 0
            A(l,k,j,i)="0"
            ELSE
            A(l,k,j,i)="0" !after the second round another program called         "bewertung" (in german this means "evaluation") checks if the user input matches the codes
             CALL Bewertung (spielfeld(n),l,k,j,i,sB(n),wB(n))
              IF ((sN(n)==sB(n)) .and. (wN(n)==wB(n))) THEN !if they match then the numbers should stay the same and the entries in the matrix should stay the same too
              field(n+1,1)= l
              field(n+1,2)= k
              field(n+1,3)= j
              field(n+1,4)= i
              ELSE
              A(l,k,j,i)= "1"
             aus = aus + 1
             ENDIF
             ENDIF
       ENDDO
     ENDDO
   ENDDO
ENDDO
END SUBROUTINE
Here are the errors I got:
loesen.f(17): error #6410: This name has not been declared as an array or a function. [A]
A(l,k,j,i)="0"
loesen.f(19): error #6410: This name has not been declared as an array or a function. [A]
A(l,k,j,i)="0" !ab der zweiten Runde wird geschaut, ob die Kombiantionen von der eingabe des Nutzers übereinstimmen mit den noch möglichen Kombis in der Matrix
loesen.f(20): error #6351: The number of subscripts is incorrect. [SPIELFELD]
loesen.f(27): error #6410: This name has not been declared as an array or a function. [A]
A(l,k,j,i)= 1
compilation aborted for loesen.f (code 1)
mecej4
Error messages from a failed compilation are often hard to understand, but in this case they are very clear. The two variables Spielfeld and A have not been declared as arrays. Apparently (I am guessing), you want Spielfeld to be a 1-dimensional array and A to be a 4-dimensional array.
There is also an ambiguity in the statement
The first argument, SPIELFELD(n), in the absence of a declaration for SPIELFELD as an array, would be treated as the value of a REAL-valued function that takes a single integer argument, n. Similarly, A could have been intended to be a CHARACTER or REAL-valued function of four integer arguments.
mecej4
crash1010
Thanks a lot for the reply! It works now.
