ifort: command line warning
Trupti
ifort: command line warning #10006: ignoring unknown option '-fallow-argument-mismatch'
I get the above error while using make command in CosmoMC/source directory.
Can anyone help me out with this?
PrasanthD_intel
Hi Trupti,
There is a dedicated forum for handling Fortran related issues (Intel® Fortran Compiler - Intel Community), where you can get better responses whether the flag is supported or not. I am redirecting this query to that forum.
Prasanth
mecej4
Trupti, you probably used a makefile that was created for use with Gfortran. Many compiler options are specific to a particular compiler. Read the Ifort documentation to find out which options will work for you.
The -fallow-argument-mismatch is discouraged even with Gfortran.  Better fix the source code in this case than search for compiler options.
sternbg
User makefiles are not the culprit – The option is being stuffed into FCFLAGS by mpif90 itself, e.g., from:
<INTEL_ROOT>/compilers_and_libraries_2020.4.304/linux/mpi/intel64/bin/mpif90
A simple mpif90 -V  unnecessarily triggers the warning:
$ env | grep I_MPI
I_MPI_F90=ifort
I_MPI_CC=icc
I_MPI_ROOT=/opt/intel/compilers_and_libraries_2020.4.304/linux/mpi
$ mpif90 --version
ifort (IFORT) 18.0.3 20180410
Copyright (C) 1985-2018 Intel Corporation. All rights reserved.
This sure looks to be a bug in the release scripts.
Here's an execution trace, filtered for some key lines:
$ bash -x `type -p mpif90` -V |& grep -E 'FC=|ver=|major=|-fallow|-gt'
+ FC=gfortran
+ FC=ifort
+ gfort_ver=18.0.3
+ major=18
+ gver=
+ '[' 18 -gt 9 ']'
+ FCFLAGS=' -fallow-argument-mismatch'
+ eval ifort -fallow-argument-mismatch ''\''-V'\''' -I/opt/intel/compilers_and_libraries_2020.4.304/linux/mpi/intel64/include/gfortran -I/opt/intel/compilers_and_libraries_2020.4.304/linux/mpi/intel64/include -L/opt/intel/compilers_and_libraries_2020.4.304/linux/mpi/intel64/lib/release -L/opt/intel/compilers_and_libraries_2020.4.304/linux/mpi/intel64/lib -Xlinker --enable-new-dtags -Xlinker -rpath -Xlinker /opt/intel/compilers_and_libraries_2020.4.304/linux/mpi/intel64/lib/release -Xlinker -rpath -Xlinker /opt/intel/compilers_and_libraries_2020.4.304/linux/mpi/intel64/lib -lmpifort -lmpi -lrt -lpthread -Wl,-z,now -Wl,-z,relro -Wl,-z,noexecstack -Xlinker --enable-new-dtags -ldl
++ ifort -fallow-argument-mismatch -V -I/opt/intel/compilers_and_libraries_2020.4.304/linux/mpi/intel64/include/gfortran -I/opt/intel/compilers_and_libraries_2020.4.304/linux/mpi/intel64/include -L/opt/intel/compilers_and_libraries_2020.4.304/linux/mpi/intel64/lib/release -L/opt/intel/compilers_and_libraries_2020.4.304/linux/mpi/intel64/lib -Xlinker --enable-new-dtags -Xlinker -rpath -Xlinker /opt/intel/compilers_and_libraries_2020.4.304/linux/mpi/intel64/lib/release -Xlinker -rpath -Xlinker /opt/intel/compilers_and_libraries_2020.4.304/linux/mpi/intel64/lib -lmpifort -lmpi -lrt -lpthread -Wl,-z,now -Wl,-z,relro -Wl,-z,noexecstack -Xlinker --enable-new-dtags -ldl
The opt stuffing is new as of version compilers_and_libraries_2020.x; the -gt version conditional inside mpif90 has been present in releases from previous years.
Michael
Steve_Lionel
If I recall correctly, you want to use mpifort, not mpif90 (which assumes gfortran).
