ifort creates empty ~/intel/ism/rm
Karl_Yngve_L_
Whenever I run ifort it creates an empty directory tree "~/intel/ism/rm". I found https://software.intel.com/en-us/forums/topic/509368 forum thread from a year ago where Steve Lionel claims this should not happen and that the developers have been notified. However, this still happens today in the newest versions.
Is there any way to prevent this?
I have asked the developers again why this happens. I can't find a record of my earlier request.
The developers tell me that if the environment variable INTEL_DISABLE_ISIP  is defined, then the folder will not be created. Try that and let me know if it works for you. This is related to the anonymous usage collection feature that you can opt in to (you have to opt in, it is not enabled by default). I'd think that if you are not opted in that it shouldn't create the folder but it doesn't work that way for now.
Karl_Yngve_L_
Dear Steve,
Thank you for your attention to this issue. I've tried to export the environment variable INTEL_DISABLE_ISIP as you've suggested. I tried both "export INTEL_DISABLE_ISIP=1" in my shell and through my ".bashrc" file. But the folder is still created. Note that I did not opt in to the anonymous usage collection feature.
To be entirely specific, I do this:
ifort <options> file.f90
And the "~/intel/ism/rm" is still being created.
I am now told that the INTEL_DISABLE_ISIP is relatively new, suggesting that you'd need compiler version 15.0.2 or 15.0.3. Which version are you using?
Karl_Yngve_L_
> ifort -V
Intel(R) Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0 Build 20150407
Copyright (C) 1985-2015 Intel Corporation.  All rights reserved.
It is unclear to me if my version is 15.0.2 or 15.0.3; it only says 15.0. I am not sure if the build date is based on when I installed it or if it is a date specific to the current version.
Karl_Yngve_L_
Update: The version I have installed might also be parsed from the install path, which is: "/opt/intel/composer_xe_2015.3.187"
Lorri_M_Intel
That is update 3, but I don't understand why that wasn't displayed in the logo-banner.
What do you see with "ifort -v"  (that's a lower-case V, not upper case, for this question).
Build date is the day the compiler was built for the kit.
              --Lorri
Karl_Yngve_L_
> ifort -v
ifort version 15.0.3
This displays the expected version 15.0.3.
