ifort: error #10037: could not find 'link'
Thijs_C_
Hi everyone,
I have installed Intel Composer XE 2013 SP1 (evaluation version), since I need it for a shortterm project.
I also installed Visual Studio 2012 today before installing the Intel Composer.
Now when I try to run a simple 'Hello_world.f' program (with the command 'ifort Hello_world.f'), I get the following error:
I have been searching today for an answer, which led me to making changes to 'compilervars_arch.bat' and 'compilervars.bat'. In the end it still had no results, and therefore I reinstalled both VS2012 and Intel Composer again.
I have included "C:\Program Files (x86)\Intel\Composer XE 2013 SP1\bin\intel64;" to the PATH environment variable, because otherwise I would get the error that the ifort command is not found.
I hope you guys can help me, and if you need more information, feel free to ask.
Steven_L_Intel1
How are you starting the command prompt session? You should not have to edit the .bat files.
Use Start > All Programs > Intel Parallel Studio XE 2013 > Command Prompt > Parallel Studio XE with Intel Compiler XE 14.0 > Intel 64 Visual Studio 2012 Mode
If from this session you still get errors, please copy the entire session log, starting from the beginning, into a reply here.
Thijs_C_
Thanks for the quick response!
I was running a normal Windows Command prompt session...
Now it does indeed work!
Thanks again.
Steven_L_Intel1
From a plain command prompt session, you'll need to do a "call <path to>compilervars.bat intel64 vs2012"
