ifort in ubuntu can not read /* */ sign
gumbira__gugum
I am trying to install FVCOM in ubuntu with ifort version 18. after setup the libraries, I try to compile the module and when i type make in the terminal this error showed up. Its look like the ifort cannot read this sign /* */ in the fortran module. I attached the mod_prec.f90 also. any help will be great thank you.
make: Circular mod_prec.o <- mod_prec.o dependency dropped.
/usr/bin/cpp -P -C -traditional  -DIFORT -P -C -traditional    -DWET_DRY -DMULTIPROCESSOR    -DLIMITED_NO  -DGCN                                        mod_prec.F > mod_prec.f90
ifort  -c   -I/home/gugum/Documents/fvcom-4.1/FVCOM4.1/FVCOM_source/libs/install/include        mod_prec.f90
mod_prec.f90(1): error #5082: Syntax error, found '/' when expecting one of: <LABEL> <END-OF-STATEMENT> ; TYPE INTEGER REAL COMPLEX BYTE CHARACTER CLASS DOUBLE ...
/* Copyright (C) 1991-2016 Free Software Foundation, Inc.
mod_prec.f90(16): error #5145: Invalid blank/tab
   <http://www.gnu.org/licenses/>.  */
mod_prec.f90(20): error #5145: Invalid blank/tab
   include it implicitly at the start of every compilation.  It must
mod_prec.f90(27): error #5120: Unterminated character constant
/* glibc's intent is to support the IEC 559 math functionality, real
mod_prec.f90(27): error #5144: Invalid character_kind_parameter. No underscore
mod_prec.f90(28): error #5145: Invalid blank/tab
   and complex.  If the GCC (4.9 and later) predefined macros
mod_prec.f90(30): error #5277: Syntax error, found ',' following statement keyword
   whether the overall intent is to support these features; otherwise,
mod_prec.f90(32): error #5145: Invalid blank/tab
   define these macros by default.  */
mod_prec.f90(36): error #5145: Invalid blank/tab
/* wchar_t uses Unicode 8.0.0.  Version 8.0 of the Unicode Standard is
mod_prec.f90(38): error #5276: Unbalanced parentheses
   2015-05-15).  */
mod_prec.f90(38): error #5145: Invalid blank/tab
   2015-05-15).  */
mod_prec.f90(40): error #5145: Invalid blank/tab
/* We do not support C11 <threads.h>.  */
mod_prec.f90(1): catastrophic error: Could not recover from previous syntax error
compilation aborted for mod_prec.f90 (code 1)
makefile:42: recipe for target 'mod_prec.o' failed
make: *** [mod_prec.o] Error 1
jimdempseyatthecove
Look in the IVF (or the Fortran Standard) documentation and you will find that /* ... */ is not a comment indicator.
However, the IVF pre-processor does support these comment indicators. You may get satisfactory results adding -fpp command line option.
!    comment, all forms, anywhere on line
!, C, or *   comment line, fixed form, column 1
Jim Dempsey
gumbira__gugum
I am sorry. I don't understand your explanation. I just compiling the program with a lot of fortran program by typing "make" command in terminal then it compiling the whole fortran program but not the program with this sign /* */. could you please expand a bit in which part I should place -fpp command as you suggested ?. I use intel fortran compiler in ubuntu to compile the program.
Lorri_M_Intel
Ah, this is the source of the problem:
This is the C PreProcessor, and does not understand Fortran syntax.
It also is changing a file that is seemingly in Fixed-form into one that is considered free-form.
I looked at your actual file, and you should be able to resolve this by:
1) Remove the "cpp" line I referenced here
2) Change the name of the file in your "ifort" line, to mod_prec.F
      I didn't see any conditional compilation in the file. The extension ".F" will cause the Fortran PreProcessor to be automatically invoked, which should remove your C-style comments.
                         --Lorri
jimdempseyatthecove
Your make file will likely have a MAKE variable defined that contains the compiler command line options. For example for the optimization level (-O, -O0, -O1, -O2, or -O3). On this variable definition line you would add -fpp. For example,if the make file defines a MAKE variable for specifying the Fortran options (flags) as:
FFLAGS=-O2
You would add -fpp to the list of options:
FFLAGS=-O2 -fpp
Jim Dempsey
Steve_Lionel
And since you seemed uncertain about Jim's reply, I will repeat that  /* and */ are NOT valid Fortran syntax and you should not be using them in Fortran source files.
jimdempseyatthecove
*** note, Intel Fortran has its own pre-processor, named "fpp".
Use fpp instead of cpp.
*** note 2
The Fortran pre-processor will not convert Fixed Form Fortran files (e.g. mod_prec.F) into Free Form Fortran files (e.g. mod_prec.F90).
While you can use the Intel fpp directly to produce an output file for later compilation by ifort, the Intel Fortran compiler accepts the -fpp option which will, for example, pre-process mod_prec.F into <compiler generated temporary file name>.F, thus preserving the Fixed Form format. The temporary file is then used as the Fortran source file to produce the object file.
Jim Dempsey
jimdempseyatthecove
This may work (or be close).
ifort -c -fpp -DIFORT -DWET_DRY -DMULTIPROCESSOR -DLIMITED_NO -DGCN -I/home/gugum/Documents/fvcom-4.1/FVCOM4.1/FVCOM_source/libs/install/include mod_prec.F
The above will pre-process, using fpp, and the -Defines the input file mod_prec.F into a temp file.F and then compile that
Jim Dempsey
mecej4
A comment about the title of this thread, which seems to convey an expectation that a Fortran compiler should "read /*..*/"... This expectation is wrong.
Remember that whether you use an external preprocessor such as CPP, FPP, etc., or use the compiler's own preprocessor pass (which you can cause to be run by using options such as -fpp), the output of the preprocessor should be valid Fortran source code. If that is not the case, blame the preprocessor, not the compiler. The built-in Fortran preprocessor of a compiler is limited in its capabilities. You should never expect it to be a full-fledged macro processor.
The file that you posted in #1 is not valid Fortran source code. Either you did not take the CPP output, or your CPP did not work as expected. A C preprocessor should not be expected to be able to handle Fortran source with added directives.
