ifort + lapack/blas lib
Rafael
Hi, I hope this is the right place to post my question. I am trying to run a program which needs the LAPACK/BLAS library. I have been able to set up the library but when I try to run my program I get this error:
... SiBDRV.o -g -fast -L/home/rosolem/lib/netcdf-4.0.1+ifort-10.1/lib/ -lnetcdf -L/home/rosolem/lib/lapack-3.1.1+ifort-10.1/lib/ -llapack -lblas -lpgmp -lpthread -o SiBD3
IPO link: can not find -llapack
ifort: error #10014: problem during multi-file optimization compilation (code 1)
make: *** [SiBD3] Error 1
All the paths (netcdf and lapack) are correct, but somehow it doesn't find the 'lapack'. I am new with ifort/lapack and I'd appreciate if someone could assist me with that. These are the Makefile options/flags I am currently using:
# BLAS-(64-BIT)
LALIB = /home/rosolem/lib/lapack-3.1.1+ifort-10.1/lib/
# Netcdf
NETCDFINC = /home/rosolem/lib/netcdf-4.0.1+ifort-10.1/include/
NETCDFLIB = /home/rosolem/lib/netcdf-4.0.1+ifort-10.1/lib/
# Includes and Links
INCLUDES = -I$(NETCDFINC)
LINKS = -L$(NETCDFLIB) -lnetcdf -L$(LALIB) -llapack -lblas -lpgmp -lpthread
# Fortran90 Compiler
# Intel 8.0 compiler
F90 = ifort
F90FLAGS = -g -O3 -DPGF=1 -fast -fpe0 $(INCLUDES)
# F90Linker Arguments
LNKFLAGS = -g -fast $(LINKS)
This is the make.inc when I first install lapack:
FORTRAN = ifort
OPTS = -O3
DRVOPTS = $(OPTS)
NOOPT = -O3 -fltconsistency -fp_port
LOADER = ifort
LOADOPTS = -O3
Finally, some additional information regarding machine, and compiler/libraries version:
Kernel: Linux
Mahcine: Intel Xeon CPU E5472 @ 3.00GHz
Processor: x86_64
OS: GNU/Linux
Intel Fortran Compiler for applications running on Intel 64, Version 10.1 Build 20080801 Package ID: l_fc_p_10.1.018
LAPACK version 3.1.1
NetCDF version 4.0.1
Thank you,
Rafael
Kevin_D_Intel
It appears the compiler options used + source code (init_sibdrv.F90) have aggravated an internal compiler error when compiling init_sibdrv.F90.
Our latest 11.1 release might contain a fix, so if you can upgrade beyond the 10.1.018 compiler you are using you might be able to continue using the high-level optimizations you have chosen. Otherwise you may have to compile only init_sibdrv.F90 at an lower optimization level, like -O2 or even -O1 or remove -fast or even -g, to avoid the error and successfully compile the entire application at the higher opt levels.
Kevin_D_Intel
Have you verified a LAPACK library like this actually exists:
/home/rosolem/lib/lapack-3.1.1+ifort-10.1/lib/liblapack.a ?
Rafael
These are the files I have in /home/rosolem/lib/lapack-3.1.1+ifort-10.1/lib
blas_LINUX.a
lapack_LINUX.a
tmglib_LINUX.a
Kevin_D_Intel
The (ld) linker -l<library> option expects the library to be named with a "lib" prefix and suffix like ".a", but that one drop both the prefix and suffix when specifying the library in the option.
To use the syntax appearing in the LINKS variable in your makefile, your libraries need to be named like this:
libllapack.a libblas.a libtmglib.a
You could also rename them (add the lib prefix) so they become:
libllapack_LINUX.a libblas_LINUX.a libtmglib_LINUX.a
and then change LINKS (add the _LINUX suffix) in the makefile to be:
LINKS = -L$(NETCDFLIB) -lnetcdf -L$(LALIB) -llapack_LINUX -lblas_LINUX -lpgmp -lpthread
I do not see an explicit use of the tmglib in the makefile excerpts provided so its use is unclear.
Rafael
Thank you! It seems that I am able to compile the code, but now I get a different message:
init_sibdrv.F90(554): (col. 8) remark: LOOP WAS VECTORIZED.
backend signals
fortcom: Severe: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
ifort: error #10014: problem during multi-file optimization compilation (code 3)
make: *** [SiBD3] Error 3
I have included tmglib in LINKS, as follows:
LINKS = -L$(NETCDFLIB) -lnetcdf -L$(LALIB) -llapack_LINUX -lblas_LINUX -ltmglib_LINUX -lpthread
Kevin_D_Intel
Rafael
Dear Kevin Davis,
I have successfully compiled my code after removing the -fast flag.
Thank you for your help.
R
Kevin_D_Intel
Glad to hear that Rafael. The -fast option is a short-hand notation for several separate options. For 10.1 compiler you are using, -fast (for Linux) enables: -ipo, -O3, -no-prec-div, -static, -xT
Removing -fast compiles the program at the default optimization level, -O2, if no explicit optimization level is specified. You can, if interested, explore the performance benefit of any individual option -fast enables if you wish.
The two options I suspect might cause the internal compiler error are -O3 and -ipo.
zhangquan09
Dear Rafael:
I'm also using the Sib3 model now, but I don't know what the library "pgmp" stand for, and whenever I complie the code, there's error indication like this" cannot find -lpgmp".
zhang
mecej4
The -lpgmp flag indicates that the library libpgmp.a (or libpgmp.so) is to be linked with the other objects.
It can be either the GNU arbitrary precision library, or another library with the same name but different purpose. You will have to read the documentation of the software that you are trying to build.to find which of these possibilities is the correct one to use.
TimP
Did you select a PGI compiler section of the makefile? libpgmp.so would be the OpenMP library for pgf90 and pgcc, analogous to libiomp5.so for ifort. One more indication why it's better to use the compiler's options rather than select specific processor-dependent libraries. In that connection, the pgf90 -mp (OpenMP option) won't be interpreted as -openmp by ifort, as it is an obsolete ifort option with different meaning.
